This is as far as I can pull out the SDS board because there is an 8.2ohm 5 watter that is soldered to chassis and SDS board, preventing pulling the board farther away.
Here are the best pictures I got of what's behind the SDS board. It looks like there are C86, C103, R149, R85, R120 and R144. CR5 and CR7 are gone. C91, C98, C97, R135 and C92 are present but inoperative, all functions replaced by parts on the SDS board. C102 seems to be gone as well as R1, R2, R131 and R132. CR6 and R142 seem to be on the SDS board.
That grey cylindrical fuse-like part is I don't know what. I think there's something wrapped inside it. It's connected to the left-most t-strip terminal of the 5-way t-strip which a stock chassis has for R131 and R132. It's other end is the thin blue wire that connects to C10 on the SDS board.
The thin blue wire is connected to SDS cap C10 which then connects to C86. C86 connects to the left-most t-strip terminal where there is also a white wire which used to connect to (before I clipped it) the grid return resistors, R121-124. R131 is connected to something I cannot see, perhaps the 3rd from left t-strip terminal on the 5-way t-strip where R120 and R85 are connected. R120 and R85 connect to C102 and C102's other end is connected to the fuse it looks like. The only other remaining part I see is C86 whose other end connects to a vertical 3-way t-strip to which incoming AC is connected.
2 white wires from the power transformer connect to that 5-way horizontal t-strip, the 2 right-most terminals. They connect to green and brown leads that go to various other areas of the chassis.
There are 2 orange wires emanating from the other side of the power transformer that connect to the bottom (or right side of the chassis depending on your vantage point) of the SDS board, to the rectifier and 8.2ohm resistor I'm guessing. I can't really get the board pulled away enough to see.
I think that's about it for underneath the SDS board. Does it give a clue to anything?
