Hmmm, no mention of the cracked plastic gear in the thread. Has that been overlooked?
Hi there, welcome to AK, nothing has been overlooked, the gear shows some stress cracks, yes, but it is firmly held in place, last week I went through it again, cleaned every switch again, and still no cueing and no auto return, so for now it is in storage, awaiting a fix, or a donor unit.
Would the tonearm assembly from the SL-1600MK2 work ?:scratch2:
There is a little micro switch activated by hi and lo spots in that white disc the worm gear spins. If it is dirty or hanging, could cause the issues you are experiencing.
I would not suspect the motor unless you have tried putting 12v dc to it and it fails to spin.
Scott T.
One of these on mine is not right - several thousand ohms open and closed (removed from the tonearm.) Fortunately they are dirt common parts and bought 2 replacements from a local electronics surplus store for $0.89 ea. These are great fun to gain access to. The chips and transistors for the arm control board are all still available and cheap. I picked up one of the 4011 chips as it is mentioned as a possible cause in the service manual ($0.25)
Hi, where are you sourcing those chips? I have a 1700MK2 with dead automation.
I got mine from Halted (Halted.com for those not local to the bay area.) Mouser also has them for $0.50 these are just CMOS quad and gates. Most of the chips on the logic board seem available as well, not all but most. I will keep looking and see if I can find sources for all. Maybe we can pool some $ and do a group buy as the shipping will be more than the parts. I also have a few accounts with obsolete parts brokers that are a pain to deal with for one or two parts.
Steve
Are you sure it's the board and not one of those micro switches? I have re-flowed the arm control board and replaced all of the electrolytic caps and still no joy. Like I mentioned I do seem to have a bad switch.
Sure would be great if we are able to re-name (and show how to do so) this thread to 'How to fix the auto return on the SL-1700MK2'!!!
Yeah, IC's, it would be great to get my 1700 online, I have taken the all arm assembly apart tested every switch (mechanical and optical) and they are all good, there is just no power to the board (if memory serves me right) it is related to a bad IC.
I have been entertaining the idea of modding the TT for manual operation only, by getting a 1200 arm assembly, but if the IC's are still available getting the 1700 back to it's original form would be great.
Keep me posted.
John
