If you must have a tuner, how about the T-1. Readily available in black.I am usually a silver fan but I like that look a lot. If I had that CT-7000 I'd go with a black set up.
Well....yes.??? Don't all true Yamahaphiles have one?Glenn, you have a black CT-7000?!
Sorry, I don't get it.
I'm looking at this photo:
The look / design is nothing special to my eye, the front actually looks sparse compared to most vintage integrated amps.
Does look better than a lot of the black gear of the last 20 years, but I don't think it's an especially beautiful retro design.
Just my two cents. Snade
It needs BOTH analogue and Digital VU meters!![]()
I like to see amplifiers with at least some sort of indicator to warn me of the onset of clipping, overload, DC at the output (guess you'll know that for sure...when it's too late.)
I see a lot of high end amps with nothing more than a power-on LED.
All the MX amps have clipping indicators, they would light up when the amplifier clips thereby warning you to back off the volume. The last MX-1 and 2 did away with those unfortunately but to bring both to clipping would take a lot of work.
Have to agree with Yamaha1 there, Yamaha amps (even the big ones) never really went crazy with lights. I always thought the red bar indicators were like a power station and actually quite classy- and they could always be turned off. The later MX630/830 etc had a clipping indicator for the L and R and that was handy.
An amp without a protection relay is like a car without seatbelts- and they should be illegal. The only japanese amps I can think of that didn't have relay protection were HK's PM540/650/660 range and they used a mute input to the power amp (not much use if the outputs go huh?) The only other I can think of was that huge marantz power amp that used crowbar SCRs to blow the power fuses if I remember correctly. Inelegant and silly. Relays are more than big enough to handle any power amp.
Nothing like blown speakers to degrade the sound...because my super megabuck amp had no speaker protection in it...
