Mister Pig
Pigamus Maximus
I have an old Sony cart that I like and I think Sony was on to something but due to the CD's takeover it closed shop. I wonder if this design would be a worth while one.
Sony used a Figure 8 coil to address the recurrent problems of moving-coil : low output, field-disturbing iron core, and increase of coil turns to increase output.
By giving one part of the armature a 90° twist, the two halves of the coil do not cancel each other out but produce voltage with both inward and outward movements.
No need to use a stronger iron core or increase the number of coil turns : linearity is improved, the cantilever isn't burdened by a heavier coil and output is doubled - simple.
They are a LOMC but they were designed with replaceable stylus assemblies, which is something that I think the market is missing When you damage or wear out a MC cart its either trash or you have to send it off for a retip. Having one where you can order a new tip, would be something that might be an advantage over competitors.
Not sure if it is the same cartridge architecture. But Transfiguration licensed the Sony ring magnet design and then improved upon it. They make very nice cartridges.
There is a degree of stability that is advantagous to a fixed mount stylus design, and given the gap tolerances in a moving coil cartridge, it seems there are distinct advantages of the design.
Regards
Mister Pig
Me like!
