JP
7480 74111110101115
...but the always-reliable JP beat me to it.
I've always considered myself a bit of a flake. Sorry I missed the show - my trip was cancelled.
You missed 16" of snow. We ended up staying up all night with John Statz, drinking and arguing about politics. Amazing fun, he's a great kid and a wonderful musician. We have another one Feb 6, Peter Mulvey. Be there.
"It results in a sound that is particularly offensive to women." Interesting observation.
the part about the diamond rotating because it's elliptical is gibberish. It can chatter, but that's from different forces.It reads like the marketing piece it appears to be. Did they provide any details on the test setup so it can be duplicated, or actual measurements?
Its not the stone causing the increase or decrease in surface noise, that's the cantilever. The loudness and duration of pops and tics is due to the cantilever momentarily swinging in free air, and or uncontrolled wave forms on the cantilever pipe.Hmmmm, I've had mixed results. I found the conical on my DL103R to be quieter than the special elliptical on my old DL110. Then again I had some Nagaoka JewelTone JT322 carts which had Shibata tips which I found to be quite noisy in terms of surface noise. Then in direct contrast to that I have a Denon DL303 with a replacement Garrott Bros Alu Alloy cantilever and Shibata tip which is by far and away the quietest cartridge I've ever heard.
I suspect there are good and also bad examples of all tip types on carts. Having said that, I daresay my abillity to setup a cartridge properly has no doubt improved since I tried the old Nagaoka JewelTone JT322 so it could have been a setup issue.
Surface noise is a record surface condition problem, a stylus that sits lower in the groove and scans more groove wall vertical area. It's likely to find more crud.
The solution is a clean quality pressing, not reducing the resolution of the scanning, which compromises full proper recovery of the content.
That's a resonance problem with a given arm, enhancing the noise. No other relationship is likely if the bearings aren't rattling.I'm not sure I completely buy that explanation because higher end arms also decrease surface noise ,regardless of stylus type.
