Ooooh, looks pretty. Love the grain in that wood. Is this getting the same inside treatments as the Russco tables?
BillWojo
The speed selection ribbon came in from the UK today, probably the most complicated little part to replace…great tutorial here: https://www.theanalogdept.com/59805.htm
The two separate ends require some disassembly for the install, she’s working at all speeds again now
View attachment 2449272 View attachment 2449273![]()
Very nice work. Enjoying your thread. Could you please share the vendor for the speed selection ribbon? Thanks.
Andy - you’re making great progress in short order. You have some great skill here. Curious about a couple of things. Is the open space on the back of the table for a second armboard? Second, appears the left side is a bit wider than the right. Assume it’s purposeful?
It's marvelous but aren't you gonna have a hell of a time trying to level the TT in the plinth using the 4 knurled knobs? I mean you're gonna have to pull the chassis out of the plinth for each tiny adjustment. Am I missing something?
Sounds good to me. If you can take off the top, level it, then put it back... All good!The plinth design is really a plinth within a plinth, and the top plate, what I term “show wood” doesn’t have to be permanently attached; this type of approach would allow for the use of the rubber bumpers and leveling with the wheels on the substrate.
Working off an on the last few days has gotten me closer, but my test fit, didn’t fit![]()
I hate it when that happens! That bubinga is really going to be beautiful, though.
Nice mitre's.
Have you ever tried dovetail jointery? I love the stability and strength. You'll never see a corner swell and open up.
This cabinet is 48"W X 19" D X 28" H. I built it years ago to hold my CD''s.
I glued up smaller boards, alternating the grain to cancel cupping and twisting. I began with long boards, cut so when the carcass was assembled the grain would appear continuous from one side to the next. I aligned the grain for the drawer fronts for the same reason.
When I had the Garrard 301 I started working on a plinth by gluing up different colors of maple boards. I wanted to create a natural looking stripe in each panel for the plinth.
After I gave the 301 back to my friend I misplaced the panels. The cutoff is all that remains.
My boards will turn up one of these days..
II saw a book years ago titled "All about Wood". I opened it and the first sentence was "Wood comes from trees".
I was amused thinking this book is really going to start from the beginning of the story.
The author explained further: Wood comes from trees and is therefore unpredictable.
That's the challenge. Not insurmountable, it just takes a lot of planning and the right tools.
Keep up the good work!
Beautiful workmanship.
I love dovetails, can't beat the strength of wood.
Nice plinth, Andy!Excellent craftsmanship!
Thank you.Rich:
Meant to say that drawers are great practice, and have to be precise, very nicely done!
