Power supply...So I guess since its the same on both channels, not coming from the input stage it must be something that ties them together.
I wouldn't worry about it..Something's drawing down the positive rail after its turned off. The negative side power supply cap will hold close to the -42v after you power the unit off. The +42v supply cap will starting dropping as soon as you power it off.
Lift them from the circuit and check them. Do they look original ?R571&/or 572 toast?.?.
Your Zetex transistor is shorted..Yes...they look original. If I check voltage on I believe the side of the D572,R571&R572 junction (physically touching the diode lead) I get 20v. But if I go on the other side of both R571 & R572 I get the 42v.
Exactly what I would expect to see at the base of TR571..If I check voltage on I believe the side of the D572,R571&R572 junction (physically touching the diode lead) I get 20v
Ok..went back and checked this on the outputs I am getting closer to +65 on TR483 and -65 on TR481. 0.65v from the resistors on both, and zero volts on the other leads as indicated.Are you getting 19vdc to one side of R489 and R490 feeding the emitters of TR481 and TR482 with .7vdc ?
Seems to be ok as I now get 20.8v on one side and zero on the otherYou do realize that the ZTX is EBC and the 2SC734 is ECB..
