Do you have replacements for both ?With the 2014i have 67 v on all three leads of both TR572 & TR573
I have a 2N5401 I could replace TR573 with? I do have another 2SD2014 and the original D476A which I could put back in. It might be still goodDo you have replacements for both ?
Would work .. The pin out is EBC for the 2N5401I have a 2N5401 I could replace TR573 with?
Check it for shorts with your meter before installing it.the original D476A which I could put back in.
I just pulled both transistors out and tested them for shorts. Seems ok on both. Originals test ok too. I'll put them in and recheck voltagesWould work .. The pin out is EBC for the 2N5401
D571, c572&573, D572, C576, D573, C579,C580. I had replaced TR572& TR573 but just put originals back in.When you get a chance. What all have you replaced in the power supply so far ?
Wait..meter issues again....one secJust tested with original transistors in...relay works now....but....I have Zero volts on all legs of both transistors now
Ok..all voltages on TR472&473 ok. Going to hook up scope and see what I have..of anything good....Wait..meter issues again....one sec
In the power supply..No..Would bad VR481 &VR482 cause this issue?
Same thing...no difference to output. Same situation as my video many posts ago.
What do you think the chances are of both trimmers causing identical failure in both channels ?Would bad VR481 &VR482 cause this issue?
Yep...I have the -42v at the junction. If I check the voltage between D577 &D578 I get -21, and if I check after D578 I get 0vAre you seeing -42v at the junction of R577,R578 abd D577?
Good point....What do you think the chances are of both trimmers causing identical failure in both channels ?
