I have a td-124 with Castagna tone arm. It needs some work for sure. The spindle is dry and I suspect the motor is as well. Despite being dry the platter spins easily and the motor spins by hand with a little resistance. I would like to plug it in and turn it on temporarily to see if it works at all before I remove the motor for a rebuild. So far I have resisted. Is it safe to start it up for a second to see if it works at the most basic level? Or will I damage it if it is in fact completely dry inside the motor?
