Thanks Kory
Yes audiodon, that is what I intend to do. Just finished phase 2 and tested thru HP first and then when everything looked good, I hooked up the JBL 4410a's. It seems to have changed for the better, but I don't know if anything that I've done so far would make a difference sonically or not.
Question...where along this restore should I look for a noticable change in the sound?
Tonight was pretty straight forward.
1) I sketched out the circuitry and made special notice of the diode's "polarity". CR6 and CR7. Double checked my diagraming against instructions. Clipped and desoldered old leads and installed new diodes.
Starting to put a bit of deoxit on terminals before soldering. Seems to help.
2) Replaced caps C92, C104 and C110. A lead of each diodes share a terminal with C104, so clean it well. There is alot of bulk there to flow solder thru.
3) I installed the thermister between the power cord terminal and the on/off switch lead that runs in the flex EMT to the front of the unit. On mine it's the brown weave fabric over insulation. It needs to be in the open because as I understand it, it gets hot.
As usual there is a little trepidation in powering it up after each phase. So check, check and recheck your work.
Tip...
When reusing existing stranded wire, it helps to deoxit and tin the strands.
An aside... The 7V fuse lamps work (meaning they light up), but are loose in the contact clips...think I'll solder mine in. :screwy:
I am trying to be helpfull with out giving too much info. Louis at metalbones has put alot of work into his kits so they are easy to follow, especially for the noob (like me). So for me to reproduce verbatium here what he has done wouldn't be right. Thanks Louis. :thmbsp:
May start phase 3, "Amplifier Signal Path" tonight...yum yum.
martian
