Nikko Alpha 220, Beta 20
Lastplace
AK Member
I'm considering purchasing this Nikko set up, Alpha 220, Beta 20 & Gamma 20 tuner. Info on the interweb seems positive.
Are there any issues with these units I should be concerned with?
I've not run into any issues with a similar set-up. Other than being 35+ years old and needing a good cleaning (DeOxit and bias adjustment).
Probably not as nice as your Yamaha set-up (and this coming from a Nikko fan), but worth it if the price is right.
These components are extremely well built, good layout and quality of controls and switches etc. The caps in these do dry out, I recently saw a beta preamp come in for service and 80% of the caps esr was off the charts. $400 is steep considering you will want to get it serviced to get the most out of it.
Score
Just got them home, purchased from original owner who included original boxes and manuals. Pretty much perfect condition, tuner missing a button. will be hooking them up shortly. What better to do on a snowy night?
attachment.php
Chris
Congrats!!!
Nikko gear in general is a bit of sleeper.
I have not heard those particular components but I have never heard a bad piece of Nikko gear.
Sorry I couldn't talk more this afternoon but I'm on the road this week.
Look forward to reading your impressions of the gear.
Okay to Deoxit the phono selector? i don't think the previous owner used it for 15+ years.
You should hit all controls and switches with deoxit, excersize them for at least 20 seconds each, same with the amp if its got level controls or switches on the back panel.
But after using deoxit on the potentiometers make sure you use faderlube to lube them.
Nice system! Nikko gear is a great brand. Are you planning to recap all of them? I found a difference in my Nikko Alpha II afterwards.
Whoops never used faderlube, I'll have to get some. Seems like it would go on after deoxit? I did the balance, bass & treble before installing in set up. The volume control is sealed. Didn't occur to me to do the phono select :sigh:
At some point will have amp & Preamp done. I can solder, not sure if I'm ready for these nice units.
Tony Rice sounds great on the TF-350s
told the seller if he had anything more to text me. Picking up a SAE 1800 Parametric EQ this weekend, in original carton.
Temporary Nikko set up. Taking the A-400s out for a morning run. CCR Bayou Country at 2'0 clock. The SAE Eq has a strange foot print.
attachment.php
