Nikko STA 5010 Issues...
coelacanthy
Greetings stereo experts!
I am having a few issues with my Nikko STA 5010. The right channel is the issue and can be sporadic at best. Normally toggling the input selector would reengage the right channel, along with reseting the fuse at times. I am now getting nothing and the fuse just clicks when depressed. Two questions, does this sound like the fuse is blown and What would fix the issue of having to toggle the input selector? Does that sound like it needs a deoxifying?
I love this receiver, my dad got it out of storage when I was in high school and have had it on and off now for 20 years. Please help.
Edit: It should be noted, before the click sound went into action the last I depressed the circuit breaker for the channel it emitted an awful crackle immediately after which went on for a little while.
Post a photo of the resettable fuse or circuit breaker your referring to.
Post a photo of the wire connection ( if possible ) of the two large electrolytic capacitors 3300µf/35vdc ..
Need to check out the power supply to the amplifiers.
I switched speakers and now the left channel is fine again. I was using these smaller Teac speakers with a maximum input of 15w and impedance of 4Ω. When I went back to the 100w 8Ω the left channel was fine again. Could those smaller teac speakers have blown something if they weren't rated right?
Which speakers ?
The kenwoods, which are the ones I previously used on my 2000s Phillips. I never the Teac before but they had a silver and wood color scheme and matched the Nikko nicely...bad idea on my end. It should be noted, left channel sounds great with these speakers on the Nikko.
