Ah yes I do have that (looking at owners manual now too). When switching pre & main i still have the hum. Which should I have it on, pre or main?Post a photo of the rear panel ......
On the back panel ....
It is labeled Pre & Main connect/separate
Nothing..Which should I have it on, pre or main?
That verifies the hum is generated in the amplifier circuit and not the pre-amp....When switching pre & main i still have the hum.
Good to know! Does this mean it is likely a bigger issue than deoxify would solve?Nothing..
That verifies the hum is in the amplifier circuit and not the pre-amp....
Guess we will have to wait and see...or hear..Does this mean it is likely a bigger issue than deoxify would solve?
Amazing, you determined this from the schematic? It looks like a maze to me! Do you have a recommendation for a good replacement?Replace....
C652
C654
C656
C662
First find them on the circuit board. See if they match what is printed in the schematic. Schematics are not 100% reliable...Do you have a recommendation for a good replacement?
Looking at the schematics I can locate them there but will look on the board. Would this be a desolder and resolder job? And what sort of capacitor (I am assuming that’s what these are) would fit the bill a replacement?I would Replace....
C652
C654
C656
C662
If deoxit doesn't pan out.
Ahhh Yes.Would this be a desolder and resolder job?
aluminum electrolytic ... Radial , through holeAnd what sort of capacitor (I am assuming that’s what these are) would fit the bill a replacement?
Use a film cap for this one..C652 .47µf / 50vdc
I sincerely appreciate this, I will try deoxify this week. If that does not work I will try the replacements. I am looking for these now, are they all going to be on the same circuit board?aluminum electrolytic ... Radial , through hole
https://www.mouser.com/ProductDetail/WIMA/MKS0C034700E00KSSD/?qs=OiDNLlGUHG3AsY7pkTj6pA==C652 .47µf / 50vdc
https://www.mouser.com/ProductDetail/Nichicon/UPW1V100MDD6/?qs=CDYjkSkiOKmRbjswP1xsHw==C654 10µf / 25vdc
https://www.mouser.com/ProductDetail/Nichicon/UPW1A470MDD/?qs=shjuwaDGTBAGXvxUIzqpKg==C656 47µf / 6.3vdc
https://www.mouser.com/ProductDetail/Nichicon/UPW1V101MPDAZHTD/?qs=OZe2HSnytvGfxtPC0Oh1nw==C662 100µf / 25vdc
I apologize for not following up yet. I had to put this project on hold the last few weeks...jumping back in.Pay close attention to polarity when removing from the board. Don't remove from the board until you have the replacements in hand. Or take photos and make notes. The polarity marks are on the plastic sleeves of the capacitors.
Like this example.. Stripe indicates negative lead on this example.
