Nikko STA 5010 Issues...
Probably need to clean your speaker select switches as well as the connect/seperate switch.
index.php
index.php
It is probably OK. ...Just the camera angle and lighting...
Yes..
Yes, then re-evaluted the situation.
I'll procure a can and give it a shot.
I am currently only receiving a hum and intermittent crackle from the right channel while the left sounds normal, this is the same through headphones. Do you think deoxifying could fix this? I'l definitely give it a shot, need to get a can anyways for a guitar with crackle issues on it's volume knob. Just curious as I await the delivery.
Do you still get the hum if you separate the pre-amp from the power amp with the separate switch?
Likely a capacitor in that channel or a cracked solder connection. At least it is not triggering the protect circuit.
So if deoxify doesn’t work, check the solder connections and then use an attenuator to check caps? What would the protect circuit do, just shut down everything?
When I press the right channel switch that silences the hum and crackle heard through the right channel and the left channel can play in all its glory.
Wrong switch.... According to the service manual there is a connect/separate switch. It should separate both channels at once. It is usually on the rear panel close to the pre-out / main-in RCA jacks.
Hm, where would that be located? There is a knob for a and b speakers but am using only a as b are rca jack style and i do not have any. Other that there is a balance knob for left and right channels?
