OK, here's the skinny: edit re-written better...
The NOT FM am/fm signal comes out of switch 1-a (fm pushbutton function switch) straight from the +13v supply right near the stereo lamp. FM = off = 0v, AM = on = 13v.
The NOT FM am/fm signal comes in on the tuner board's pin 12 ( line <b> on the schematic) and goes to the pa1001 stereo decoder pll chip's pin 16 as a vco killer signal shutting down the stereo decoder.
In between pin 12 which is directly connected to the function switch and power (lots of current capacity) and the tuner board's pin 20 input for the pa1002 muting chip's mute signal on pin 8 is a 100k resistor, 2 diodes and S20 the fm muting switch shown in the ON position. These could be affecting things somehow.
The NOT FM am/fm signal comes in on pin 20 of the tuner board and goes to the pa1002 muting chip's pin 8 muting input signal for the chip. It looks to me like the NOT FM am/fm signal should be either a 0 v or a +13v signal.
Thus the first signal is one I am familiar with, and it's there, but the second half of the signal is inappropriately telling the pa1002 to shut off the audio.... what's happening to it in-between?
So if you followed this,
pin 12 shows 0 and 13v on AM and FM
pin 20 doesn't.... why not....
if you need clarification, pm me an email address, and I'll send a marked up drawing. I'm working on the drawing right now...
edit it's 2k x 2k, too big to post with clear details...
