No FM reception
ok pin 12 FM -1.2MV
AM 13.2MV
pin 20 FM -2.0MV
AM 2.1MV
I just can't believe that pin 12 is at 13.2 millivolts in the AM position, especially with deoxited switches. 13.2 VOLTS is believable.
which means that pin 20 voltages are even more suspect.
What is the voltage on pin 11 of the tuner board ?
edit: and remember for all these tests, FM MUTING is OFF.
i also tried the 1000 ohm resistor and the audio is still the same with no changes
i took readings with the resistor attached... fm 0.000V am 0.159V
pa1002a typical operating voltages and pin definitions
Now we have accurate voltage readings. :yes:
perhaps NOT what we want them as, but reasonable....
Is the pa1002 chip getting really warm, or warmer than the pa1001?
PA1002a typical voltages, check them :
pin voltage function
1 12.2v paired with pin 11
2 6.4v left de-emphasis f/b in
3 5.6v left in
4 6.3v left de-emphasis f/b out
5 6.4v left out
6 6.2v right unk input function
7 6.1v left unk input function
8 xxxx mute input
9 gnd
10 6.4v 33uF capacitor bypass to ground
11 12.2v power on/off detector input
12 6.4v right output
13 5.0v right de-emphasis f/b out
14 6.3v right input
15 6.3v right de-emphasis f/b in
16 13v power in
mark, like i said in my email, when i turn the unit on i get fm audio out of both channels, the volume is very low but i get audio, then after about 30 seconds the left channel gets louder, then it cuts out, leaving the right channel the only audio still streaming at a very low volume...not sure if this means anything but its good for the thread...
Read the voltages a few posts back, and see what the chip has. I believe you need to replace ALL the electrolytic caps around that IC. Now we see if we can prove it.
You are posting while I am editing, and we're both missing stuff
3 5.6v left in
5 6.4v left out
8 xxxx mute input
9 gnd
14 6.3v right input
16 13v power in
ok mark
1-13v
2-7.55v
3-3.75v
4-7.66v
5-7.66v
6-1.87v
7-3.84v
8-xxxx
9-gnd
10-1.46v
11-13v
12-.110v
13-0.007v
14-1.94v
15-0.530v
16-13v
not good huh
I sure wish you had posted the good and bad side by side, I'm going cross-eyed.
Again, I say, replace the electrolytic caps in the circuit around it. Then re-evaluate.
Mouser.com parts numbers:
C49, C73 10uf 16v 647-UPW1E100MDD @ $0.23 ea (25v)
C76, C90 4.7uf 16v 647-UPW1H4R7MDD @ $0.23 ea (50v)
C78 220uf 16v 647-UPW1E221MPD @ $0.50 ea (25v)
C79 33uf 16v 647-UHE1J330MED @ $0.19 ea (63v)
C44, C45 0.56uf 35v 581-BQ074D0564J @ $0.21 ea (63v)
C46, C47 47uf 10v 647-UPW1A470MDD6 @ $0.23 ea
Mouser parts numbers will be edited in, :D remember nights like tonight when it's your equipment's turn on the bench and it's taking me a while to get it finished, I ALMOST made it to the bench tonight.... I wish I could be two places at once.... three actually... yard & outside maintenence work too... :D
i wont mind having my equipment on your bench or how long it takes because when i get it back i'm sure it's gonna be right.....again thanks for your help , i think i have most of these caps laying around from a previous tuner recap, i always order 2 or more of what i need...thanks, i'll get back to you when i have this recapped
PA1002a typical voltages, this unit's voltages :
1 12.2v 13v
2 6.4v 7.55v
3 5.6v 3.75v
4 6.3v 7.66v
5 6.4v 7.66v
6 6.2v 1.87v
7 6.1v 3.84v
8 xxxx mute input
9 gnd
10 6.4v 1.46v
11 12.2v 13v
12 6.4v .110v
13 5.0v 0.007v <<<<<<<<<< :yikes:
14 6.3v 1.94v
15 6.3v 0.530v
16 13v 13v
It STRONGLY looks like pin 13 of the pa1002 is shorted to ground!!! That 0.007 volts is HIGHLY suspicious
The pa1002a's pin 13 is connected to pin 18 of the tuner board.
Measure the ohms resistance between pin 13 on the PA1002a or Pin 18 of the tuner board and the ground. It will probably be close to zero ohms. If not check the resistance to pin 16 of the tuner board (not the 1002's pin 16).
Check the trace between the integrated circuit and the off board pin, LOOK ON BOTH SIDES of the board for a short, then follow the wires TO the FM de-emphasis 75/25 us switch on the FRONT panel. And check the switch itself.
If it worked before shipping, either something got jarred in shipping and shorted, OR some loose hardware bouncing around has shorted it out.
I REALLY hope the PA1002a chip survives this... it's unobtanium...
ok heres the deal with pin 13 on pa1002a, when i put the probe on it , it measures 0.250v, but if i keep the probe on the pin it slowly lessens in value, and it winds down like a stop watch from 0.250v to 0.160v before my hand gets too tired to hold it anymore
also, i'm not seeing any shorts on either side of the board, maybe these latest readings are positive? hopefully the 1002 chip isn't fried....
With the higher voltage reading, recap.... sigh.... no easy fix...
But the short could be ANYWHERE inbetween the tuner board and the de-emphasis switch on the front panel. And that's pretty buried.
i will do the recap, but if that isn't the culprit is there a backdoor here or is fm doomed for good...
as long as i can fm audio i really dont care about de-emphasis...either way i will do the recap and then report back, and i will send you info about the sx-1250 that is hopefully to be on your bench soon
mark, got the parts installing now, one question on the C44 & C45 the 0.56uf 63v avx boxed metal film caps, how do you tell which leg is positive?
