Sheesh, ALL those tantalum caps........
Ok, the probe (rca cable with the capacitor) will be connected to one of the tape monitor inputs at one of the "play" jacks, and that tape monitor lever will be depressed to the on position.
Then you will have control of the volume to the speaker with the volume control.
In ALL the probing, be very careful not to hit two pins at the same time, the lead from the capacitor IS wide enough to bridge the gap between the pins, and that's not good.
1) you will probe pin 6 of the pa3001 chip to confirm the presence of detected FM audio, and also set the volume to a low but comfortable level.
The audio level should not vary much across these tests.
2) you will probe pin 2 of the pa1001a chip to confirm the presence of FM audio AT the chip.
3) you will probe pin 4 and pin 5 of the pa1001a chip to confirm that the stereo decoder is working.
4) you will probe pin 3 and pin 14 of the pa1002a chip to confirm that the stereo signals have gotten through the L.P.F. ok.
5) you will probe pin 5 and pin 12 of the pa1002a chip to confirm that the signal is getting through this chip.
this might be the spot they are lost, it does muting in this chip.
6) lastly, pins 19 & 21 of the OFF BOARD connections are the last point before the function switches, again we are looking for audio.
uh oh, according to the schematic, this is where the fm signals go off the board, but the PICTURE doesn't show any wires on them!!!
Are there wire wraps on the underside of the board (I hope), even the AM out pin 9 is bare in the picture, but you say the AM works...
also follow the wire from pin 20, to the mute switch (as far as you can see it, we're looking for breaks...)
work the mute switch a bunch of times to get some cleaning action, to see if that makes any difference.
