PA1002a typical voltages, this unit's voltages :
pin voltage function
1
12.2v 13v
2
6.4v 7.55v
3
5.6v 3.75v
4
6.3v 7.66v
5
6.4v 7.66v
6
6.2v 1.87v
7
6.1v 3.84v
8 xxxx mute input
9 gnd
10
6.4v 1.46v
11
12.2v 13v
12
6.4v .110v
13
5.0v 0.007v <<<<<<<<<<
14
6.3v 1.94v
15
6.3v 0.530v
16
13v 13v
It STRONGLY looks like pin 13 of the pa1002 is shorted to ground!!! That 0.007 volts is HIGHLY suspicious
The pa1002a's pin 13 is connected to pin 18 of the tuner board.
Measure the ohms resistance between pin 13 on the PA1002a or Pin 18 of the tuner board and the ground. It will probably be close to zero ohms. If not check the resistance to pin 16 of the tuner board (not the 1002's pin 16).
Check the trace between the integrated circuit and the off board pin, LOOK ON BOTH SIDES of the board for a short, then follow the wires TO the FM de-emphasis 75/25 us switch on the FRONT panel. And check the switch itself.
If it worked before shipping, either something got jarred in shipping and shorted, OR some loose hardware bouncing around has shorted it out.
I REALLY hope the PA1002a chip survives this... it's unobtanium...
