I think maybe it was to gimmicky for audiophiles with the auto correlation preamps & other dynamic range processors.
But the original 700 amp & 2000 preamp are pretty straight forward audio designs.
I for one would love to own to 2 of the 700 amps a 4000 preamp quad heaven!
Be careful for what you wish. The 4000 has a motherboard with connectors. All of the processor boards plug into the motherboard. The connectors are notorious for cracked solder joints. The last 4000 I worked on had more than 100 cracked joints. The RCA jacks are easily broken and suffer from the same cracked solder joints. I won't work on a 4000.
The Phoenix Audio forum has many devoted P/L fans and followers.
P/L amps were never intended for pro sound. Like any other pro amp they could be reliable with proper cooling. If they did go down speaker damage was possible as there was no output relay. For those who are concerned about this I have an output relay board available for the 400 and the 700.
