I just got mine hooked up today. Certainly IS microphonic. Considering the design of the chassis, its not a surprise.
If i flick the chassis with my finger it rings like a bell.
The tube sockets have some play and wiggle if you reach in and push on them. So right off the bat I installed silicone tube dampers down low and up high. I made sure the tubes were fully seating by checking the height between the tubes with one having the bottom o-ring and one without.
The sockets are laying right on the fibreglass circuit board, no isolation of any kind, and the circuit board is held in place by sliding into grooves milled into the aluminum outer casing. Then the milled aluminum outer casing's milled aluminum ends are screwed into place.
Mine had considerable hum until i wiggled the tubes around and found a "sweet spot" where they made better connection. While i was wiggling the front tube the led backlighting the tube turned off and on......
Despite this, once i got it settled in, i was quite happy with how it sounds. Better than 2 "high end" preamps i have and better than the Schiit SYS i have. "Better" meaning it sounds fuller, has more air\space around instruments, instruments seem to sound more real.
I think im going to take it back apart and resolder the tube sockets to the board, touch up some other joints, add some foam dampers in between the board and the casing, and clean the tubes pins.
Maybe after l listen to another CD or two.....
