There are some really nice ARs in this thread. I'm curious what cartridges folks are using on their ARs. I use two: Shure M91ED with JICO SAS and a Grado G1+ with MCZ stylus.
I'm using an Audio Technica AT-440OOC and a Shure M97-xE. I wonder if anyone has used an Ortofon 2m, and what your thoughts/opinions of the cartridge.
I have a 2M Blue that I tried but the Shure and Grado bested it handily IMO. {b}The 2M sounded forward in comparison without the nice mids and bass of the Shure and in particular the Grado.[/B]
My particular model of XB has the unshielded motor sitting about 1/4" above the top plate and it causes my Grado to hum. It is noticeable at the lead in and between tracks but I don't notice it much during songs except during very quite passages. Between the Shure and Grado, absent the hum, I'd choose the Grado. It has really a nice soundstage and sounds "right" in my system.
I have an XA that I hope marcmorin will have time to work some of his magic on and with its motor below the top plate I expect the hum will be greatly diminished. So eventually the XA will have the Grado and the XB will have the Shure. It should be a complimentary combo.
Could you explain what you mean by the 2m Blue sounded "forward"? I'm not understanding what you mean.
That usually means bright or strident.
Beatcomber's description is better and that is what I meant when I said the 2M Blue is forward. I would suggest it is because the mids and bass of the 2M Blue are not as full as the Grado and the Shure so I hear the highs as more pronounced.
I'm also curious if anyone is using a MC cart on their AR. I've checked the resonant frequency (using the Vinyl Engine calculator) of various MC carts and there are a bunch that fall into the 8Hz to 9Hz range which is probably OK. In particular I wonder if anyone has successfully used a current generation Denon 301 or 304 on their AR.
Thanks Marc. Remind me again; What is the optimal distance between the counterweight and the pivots? And what have you used to add mass and keep it at the right location relative to the arm tube?
Another beautiful example of simplistic sweetness. There is absolutely nothing rough regarding your turntable. Your XA is completely stock, and there is nothing wrong having a stock XA. I wished I had a stock XA but it wasn't to be. May you have many years of musical bliss with your XA.![]()
