OK, I did it...
I thought incandescent bulbs were illegal in England now, with a mandatory 5 year jail sentence...?
My local Ace Hardware still has cases of them. If you shop carefully you can get the full wattage types from yesteryear.
I wouldn't be surprised if it were illegal in the UK, but it's also probably not legal to carry a pistol there either. That's what happens when you start calling a truck by a girl's name. ;)
You need to be shot. You are KILLING the environment ! Think of the children ! Think of the trees !
Wanna sell a few ?
LOL
On the serious side, you might want to use two of them in series for low power drain units, like tuners n ****, and amps like 20 WPC. Seriously, a 100 watt bulb is too much for a 20 WPC amp. (well solid state class AB that is, there are certainly exceptions)
They sell them at Lowes but I like LED.
Dialectical Behavior Therapy
DBT Department of Biotechnology (India)
DBT Drive-By Truckers (band)
DBT Dibenzothiophene
DBT Days Beyond Terms
DBT Deutscher Bundestag (German Parliament)
DBT Design Basis Threat
DBT Double-Blind Test (method)
DBT Dry Bulb Temperature
DBT Dialektisk Beteendeterapi (Sweden)
DBT Defect-Based Testing
DBT Data Base Testuale (Italian: Textual Database)
DBT Design Build Team
DBT Design Build Test (engineering)
DBT Database Transaction
DBT Design Basis Tornado
DBT Death By Tweakage
DBT Days Before Transplanting
DBT double bottom tank (ships)
DBT Deutsche Bundespost Telekom (Germany)
DBT Down by Trade
DBT Delaware Business Trust
DBT Design Build Turnkey (construction)
DBT Database Transfer
DBT Diaphragmatic Breathing Technique
DBT Directive Basse Tension (French: Low VoltageDirective)
DBT Duxbury Braille Translator (Duxbury Systems, Inc.)
Next thing you know will be DIY bulbs. A piece of tungsten wire, an evacuation and sealing chamber. Tom Edison would be proud. :)
FYI, incandescents are illegal to produce here in Germany theoretically. But they can be produced and sold for certain industrial or special use applications. Like for instance 100w 8000 hour bulbs for the red aircraft anti-collision lights on top of tall buildings. So if you are clever you can find a way to buy them. Wink wink nod nod. I'm sure that there are many other loopholes to exploit.
Cheers,
James
The ones I bought were 'rough service' ones (slightly posh :D) - for use in inspection lights and so on, to me they are still 100W bulbs which are good for UK mains voltages, and medium powered amplifiers. And if I get cross with a repair, I can kick my DBT around with less likelihood of blowing the bulb :)
