Sansui transistor substitution collection
Hi, I've been busy figuring out transistor substitutions for my AU20K. While at it I also went through BA-2000 and AU-717 service manuals to find other transistors used originally in these things and searched the forum. The info is scattered in many many threads, maybe there already is a collection of these somewhere but I didn't find it. Meanwhile I have found many more references for other Sansui model's transistors and suitable substitutions in the forum. They are also listed below. If there was any doubt in the discussion about suitability I didn't add them to the list.
Here is the list I gathered from AK Exclusively Sansui -section. So,
its not an AU20K list but rather a general Sansui list. If you spot an error please point it out, I'll update the list. Also if you know better or more suitable substitutions or transistors which are missing from this list please let us know. All additional info like if the pin order differs from original, case type, ideal usage etc. is welcome.
If there is more than one Substitution it means there is more than one option. Ie. somebody on this forum has suggested or even used these types.
Note: the suffixes might be suspect on some of these so double check from the specsheet what they mean. These transistors are all something that has been suggested by reputable forum users but frankly I don't know what most of the suffixes mean or if they are the optimal for the use. Please recheck before using and use at your own risk.
Note 2: complementary pairs have not been marked. If you need them in pairs google for the datasheet or search Mouser etc. vendor sites for the the substitute and you will find the datasheet. It usually says what the correct complementary pair is.
Original ---- Substitution(s)
2SA561 --- KSA733C (C-suffix= collector center)
2SA562 --- BC327
2SA606/2SC959 --- NTE129MCP (Complementary pair product #)
2SA706 --- KSA1381ESTU, BD136
2SA726 --- KSA992FTA/-FBU, BC560
2SA733 --- KSA733C (C= collector center)
2SA745 --- MJ15004G, upgrade: MJ21193
2SA747 --- MJ21193G (for example AU-9900/11000 output)
2SA750 --- KSA992FBU
2SA818 --- KSA1381 (pin order!), KSA1142, (2SA0914?)
2SA839 --- MJE15035, 2SC1669
2SA847 --- KSA992
2SA850 --- KSA1013, KSA992
2SA896 --- KSA1381ESTU (pin order!)
2SA899 --- KSA1142, KSA1220AYS, KSA1381
2SA908 --- MJ21193G, MJ21195G (for example AU-20K output)
2SA914 --- KSA1142, KSA1381
2SA917 --- 2N5400 (pin order!)
2SA939 --- KSA1381, KSA1220AY
2SA958 --- ??
2SA968 --- MJE15033
2SA981 -> MJ21193G and
2sc2261 -> MJ21194G
2SA1105 --- 2SA1695
2SA1106 --- 2SA1695 (avail. fr. Digikey), NJW1302G
2SB327 --- KSA1220A
2SB507 --- MJE15033G
2SB507(E,F) --- KSA1010Y
2SB526 --- MJE15033
2SB527 --- MJE15033, KSA1220
2SB528 --- 2SA1837 (TO220, fully insulated case)
2SB536 --- KSA1304Y, MJE15033G
2SB537 --- MJE15031G
2SB545(A) --- MJ21193G
2SC458 --- 2SC2240, 2SC1345
2SC735 --- BC337
2SC871 --- 2SC2240, KSC1845, or even BC549C or BC550C (pin out differences!)
2SC945 --- KSC945C (C= collector center)
2SC983 --- KSC1845
2SC1116 --- MJ21194G (for example AU-9900/11000 output)
2SC1124 --- KSC3503DSTU (pin order!)
2SC1313 --- KSC1845FTA (Must install them backwards of original 2SC1313 which is BCE the KSC1845FTA is ECB.)
2SC1364 --- KSC945C (best if used on protection board), KSC2690 (for more demanding use)
2SC1400 --- KSC1845
2SC1402 --- MJ21194
2SC1403A --- MJ15003G, upgrade MJ21194
2SC1585 --- MJ21194G, MJ21196G (for example AU-20K output)
2SC1628 --- KSC3503 (pin order!), (2SC1953?)
2SC1669 --- MJE15034
2SC1708 --- KSC1845
2SC1735 --- KSC2383, KSC1845
2SC1811 --- KSC3503ESTU
2SC1904 --- KSC3503, KSC2690AY
2SC1951 --- ZTX694B
2SC1953 --- KSC2682, KSC3503
2SC959/2SA606 --- NTE129MCP (Complementary pair product #)
2SC1983 --- TIP112F or KSD1273Q
2SC2071 --- KSC3503, KSC2690AY
2SC2238 --- MJE15032
2SC2261 -> MJ21194G
2SC2580 --- 2SC4468
2SC2581 --- 2SC4468 (avail. fr. Digikey), NJW3281G
2SD188(A) --- MJ21194G
2SD247 --- MJ15003G
2SD313(E,F) --- KSC2334Y
2SD356 --- MJE15032
2SD357 --- KSC2690A, KSC2073
2SD381 --- KSC3296Y, MJE15032
2SD382 --- MJE15030G, MJE15032
Here is some diode and zener subs I've seen mentioned while collecting transistors:
Diodes/rectifiers:
10D1 --- 1N5392, 1N5393
10D2 --- 1N5392, 1N5393
30D2 --- 1N5402G
1S1588 --- 1S2473, 1N4148
1S2473 ---- 1N4148, 1N4149
VD1212 --- 2pcs of 1N4148 connected in series
1S1850 --- MUR1620CTG (TO220) - or use 1N5393G (200V 1.5A) or 2A03 (200V/2A) to make your own Common Cathode -diode pack
1S1850R --- MUR1620CTRG (TO220) - or use 1N5393G (200V 1.5A) or 2A03 (200V/2A) to make your own Common Anode -diode pack
Zeners
EQB01-22 --- BZV85-C22 or 1N4748A
RD-13A --- TZX13A-TR
RD-15E --- ??? Maybe
1N5245BTR, comments?
RD-22E --- ??? Maybe
1N5251BTR, Comments?
I've noticed I myself have difficulty sometimes finding this thread so here are some search terms: substitution, substitutions, subs, substitute.
