The 2SC1313 is rated at 30W and the KSC1845 is only rated at 500MW. KSC2334Y and KSD1273 are better matches and are all TO220.
Type Designator: 2SC1313
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.2
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 50
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.1
Maksimalna temperatura (Tj), °C: 150
Transition frequency (ft), MHz: 200
Collector capacitance (Cc), pF:
Forward current transfer ratio (hFE), min: 150
Noise Figure, dB: -
Package of 2SC1313 transistor: TO92
Type Designator: KSC1845
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.5
Maximum collector-base voltage |Ucb|, V: 120
Maximum collector-emitter voltage |Uce|, V: 120
Maximum collector current |Ic max|, A: 0.05
Transition frequency (ft), MHz: 50
Collector capacitance (Cc), pF: 1.6
Forward current transfer ratio (hFE), min: 200
Noise Figure, dB: -
Package of KSC1845 transistor: TO92
Seems quite ok to me.
