Looking for a Sub for the 2SB527 .
Also looking for 2SC281 substitute.
And
2SA640
2SC875
2SC1211
2SA697
2SC1124
Type Designator: 2SC1313
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.2
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 50
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.1
Type Designator: KSC1845
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.5
Maximum collector-base voltage |Ucb|, V: 120
Maximum collector-emitter voltage |Uce|, V: 120
Maximum collector current |Ic max|, A: 0.05
Seems quite ok to me.
And
2SA640
2SC875
2SC1211
2SA697
2SC1124
A bit late I guess, but here you go. please take care as i did some rapid fire copying and pasting from here and there; double check suitability transistor type and suitability.
2sC281 --> KSC1815
2SA640 --> KSA992 or I typically go for the beefier ZTX795A
2SC875 --> ZTX694B
2SC1211 --> KSC2383
2SA697 --> ZTX795A
2SC1124 --> MJE15032G but that might be overkill and you could consider KSC2073
Thanks for the reply! This wil be quite helpful.A bit late I guess, but here you go. please take care as i did some rapid fire copying and pasting from here and there; double check suitability transistor type and suitability.
2sC281 --> KSC1815
2SC875 --> ZTX694B
2SC1211 --> KSC2383
2SA697 --> ZTX795A
Re the 2SC281, the original is a tubular metal case, and these are used in many instances as bias transistors in conjunction with a metal bracket/clip attached to the heatsink or driver. The KSC1815 is a plastic TO92 package, and there may need to be some creative mounting adaptation for these to be used.
Like I said above late last year, nothing can be changed anymore. The new forum software doesn't allow editing of old messages. So, the list is now useless, does have some wrong info but it cannot be corrected. Everybody realize this and recheck everything before using any replacement.There is an error on page 1 - please correct this @ToniCH
