Bwebber,
Thanks for the kind words. I absolutely enjoyed the 12LTA's to no end but would have liked them even more had I paired them with the 1001 tweeters which I didn't have at the time. You've probably seen this blog but for others it bears repeating.
https://speakerprojects.wordpress.com/2016/08/29/eminence-beta-12lta-on-open-baffle/
I found the 1001's to be almost too good but a bit forward with my Zeniths so I balanced them with rear firing Realistic super tweeters. Perhaps their output is reduced I'm not sure. All four tweets do run off the same SE amp that drives the Zeniths ( but now from the Bottlehead 2a3 as the EL84 is now driving the Lowthers ). Tried tri-amping but way too complicated for me.
I really wanted to follow conventional wisdom which says the active x-over should be used to split the HF and LF but the single ended tube amps lost their magic and sounded like cheap solid states when I tried that. I use the LF active only with my LF Alpha woofers and the summed sub output connection for the subs ( bucket subs and 8" Dayton kit ). Subs are driven by plate amps. Depending on the type of music OB woofers can be all you need. Active crossover settings I think are personal and unlike passives ( thank goodness ) they can be changed with a flick of the dial. Yes mine is currently at 70hz.
The big SE powered Zeniths are a thing of beauty unfiltered/full range with nothing in the signal path to alter their natural sound. Desert island drivers and unlike the Lowthers they have some bass.
The wonderful thing about DIY OB's is that you can tweak to your heart's content and only you can say what sounds best to you. Buying off the shelf monkey coffins means you're locked in to someone else's sonic preference. I wouldn't be concerned about measurements because if it sounds right it is right. Measurements are most helpful for those who like to pass judgement without listening.
The lyrics from this song by Cole Porter are keys to DIY open baffles:
"Before you leave these portals
To meet less fortunate mortals,
There's just one final message
I would give to you.
You all have learned reliance
On the sacred teachings of science,
So I hope, through life, you never will decline
In spite of philistine
Definace
To do what all good scientists do.
Experiment.
Make it your motto day and night.
Experiment
And it will lead you to the light.
The apple on the top of the tree
Is never too high to achieve,
So take an example from Eve,
Experiment.
Be curious,
Though interfering friends may frown.
Get furious
At each attempt to hold you down.
If this advice you always employ
The future can offer you infinite joy
And merriment,
Experiment
And you'll see"
