Open Baffle Epiphany!
speaker level connection
That's one way.
Parallel wires on main amp with a pair to speakers and a pair to plate amp is another.
I would wire like the example with a passive sub/sat set designed to be used that way. :biggrin:
Thanks openly bafled and Poultrygeist.
Speaker level works well for most applications. At least with line level I know the plate amp is not restricting the speaker's ability to run full range.
I don't trust my cheap plate amp enough to run a SET amp through it.
This is what I would like to avoid, which is why I asked if my wiring scenario would work. In the scenario which openly bafled describes, I would only be using my tube amp to drive my Zenith full rangers.
I never run my amps "through" the plate amp. I use an extra pair of speaker wires.
This is what I was asking about. I think what you're describing is what I would like to do.
Doing it this way would keep the signal going to the Zeniths untouched by the plate amp, right?
Are there any other potential drawbacks/benefits to using the hi-level inputs as described above?
Thanks again.
Yes
Benefits - can be used in system w/o preouts (like some very good integrated amps); you don't have to worry about determining if the main amp inverts polarity; some claim the signature of the main amp driving the sub amp is better.
Drawbacks - :dunno:
Drawbacks - :dunno:
Thanks a lot openly bafled.
So for someone like me who doesn't have a pre-amp, the set up you described would be the simplest way of augmenting the bass of my Zenith drivers without sacrificing the "purity" of the signal being fed to the Zeniths from my tube amp. It also seems to be a relatively inexpensive solution compared to investing in a pre-amp and a crossover/signal processor (CX2310 for example).
I hope this information will be useful to other forum readers who don't have a pre-amp and want to try out Alpha 15A bass augmentation with their full range drivers. It seems like a relatively simple solution which allows the user to have all the benefits of their main amp (driving their full range speakers) as well as the benefits that a plate amp provides, such as gain and frequency cut-off of a plate amp like the Dayton SA100.
If I'm overlooking or misunderstanding something please let me know.
Doubling up the connections from the terminals of the main amp I would question if the ohm load would change?
That's a good point. What would the change be using the Zenith 48CZ802 & An Alpha 15A?
If any one else wants to chime in on this subject that would be great. Seems like posting during the Easter weekend might not have been the best timing.
One example, the REL T/7i has an input impedance of 150,000 ohms, the main amp doesn't even know it is there.
Another, the Dayton SPA250 is 10,400 ohms; Dayton SA100 same.
It took days of periodic reading to get through this entire thread, and now I've ordered some test pieces to try out OB. I have on order two 2'X2' pieces of budget ply from home depot, a low-end jig saw and cheapie shelf brackets. I also own a pair of Visaton BG-20 full rangers that I bought on sale previously. They aren't Zenith vintage units or even Betsys, but should nonetheless give me an idea of the OB sound in my intended application. Total cost so far is under $150. Over the next week I'll throw them together and plan to try them initially in a room that currently runs an AVR, bookshelf units and Yamaha sub. I'm planning to set them up with some breathing room around them and then let the receiver's room correction determine values for the OBs and the Yamaha sub. Should be interesting to see how that works out.
If I enjoy the concept, I'll take a look at better FR drivers on appropriate panels with OB bass augmentation, although I'm slightly put-off by the complexity required to add drivers to these panels, H-frames, crossovers, etc. There is a real appeal to simply installing FR drivers on a panel, hooking them directly to an amp, and off you go. To that end, I'll consider keeping the Yamaha sub in play with FR/OB, if only to provide a enough bass presence to seem pleasing to my ears. I'll keep this thread posted on how it goes.
Look for drivers with a highish qts (about 0.7 to over 1.0). Often old vintage or less expensive equals a highish qts, what happens to lend itself best to this (the OB) situation.
Thanks for your reply. I noted that the Visaton BG-20s have a Qts of .44. I think the Visaton B200 has been more widely used in OB applications but I have these drivers sitting here, so what the hey right? I poked around on the bay earlier and large, full range vintage drivers appear difficult to come by and expensive. If my test baffles work well, I'll likely progress to Audio Nirvana or Betsy drivers, although I'd rather go straight to vintage drivers, but have trepidation about doing so. Is there such a thing as a readily available vintage 12" full range driver pair that a not-so-knowledgable buyer can acquire? I got lost earlier in the thread with model numbers, eras, etc.
I thought about getting a pair of those when I was demo-ing a quick-and-dirty OB setup like you are doing. But ended up getting a pair of Goldwoods and something else...both of which are now stored in their boxes in the closet.
I'll be curious as to your experience with the Visatons.
As for the subwoofer, I kept mine in my system. The old 8" Heppners I settled on sound great but are a bit lacking in the low end.
If I enjoy the concept, I'll take a look at better FR drivers on appropriate panels with OB bass augmentation, although I'm slightly put-off by the complexity required to add drivers to these panels, H-frames, crossovers, etc. There is a real appeal to simply installing FR drivers on a panel, hooking them directly to an amp, and off you go. To that end, I'll consider keeping the Yamaha sub in play with FR/OB, if only to provide a enough bass presence to seem pleasing to my ears. I'll keep this thread posted on how it goes.[/QUOTE]
You are off to a good start with your concept. You can find out if "The Dark Side" is something that appeal's to you.
My only suggestion for choice of FR driver would be try to stay away from one's that need correction (notch filter's) to keep the complexity down.
Some of the FR's can shout.
The use of a sub to start will be cost effective.
Thanks essNeff. I propped up the drivers today on some foam bases, naked, and ran them for a couple of hours just to exercise them before the baffle ply pieces arrive, hopefully Monday. You aren't kidding about shouting! These drivers with no treatment of any kind made my ears want to bleed. Youch! I can't wait to get them into baffles early next week, which will no doubt dramatically improve their performance. I'll post as progress is made.
The use of a sub to start will be cost effective.[/QUOTE]
I can vouch for that "shout" that some full rangers can put out... and it can be tough to tame. Your comment is right on.
I went full white trash (WT) this morning and threw one of the BG-20 drivers into an Amazon box that, when flat, had dimensions roughly 36X31, similar to the JE Labs concept. It's propped up in my room now and it sounds VERY different in baffle than naked. Much of the shrill/shriek has mellowed and the midrange has smoothed considerably. Parked out into the room it actually makes some bass too, although as noted by many others previously it is bass without the punch/slam. I can also hear the larger sound that these make as compared to box speakers. I'm pretty excited to keep moving forward.
I have 24X24 ply arriving tomorrow and will build experimental baffles "proper" to try for a few weeks. I will say that I noted already that using the Yamaha YPAO room correction and allowing it to blend in my small Yamaha sub (heresy, I know) the bass blends very nicely into the room, so at least initially I will set these baffles up in the same manner, but will also try setting them up without bass reinforcement as well.
My wife is horrified at the cardboard WT look at this time, but understands it's part of the process! :-) Maybe I'll find some banjo or music from Deliverance to make a point.
