Mr. Pig,
I liked your summation. But I feel the OB brings strengths that outweigh the negatives versus some of the other big "OB's".
I lived for almost 15 years with Martin Logan electrostat's. I came to love the sound detail, stage depth and open character. Most of those years, it was with the big original Monoliths. The weaknesses mainly centered around the need for extreme power, the limited larger dynamic swings and the ported bass of the low end.
My OB answers these very well. I may give up just a little bit in flatness of response and clarity at some freq's with my short line of 8" Tang Bands with low augmentation from a line of 10"er's, but that's about it. I gain the ability to run them with almost any amp of my chosing. I have much better bass, even now with cheap bass drivers, and my dynamics are now very good!
The Carver Amazing is a similar comparison. It needs more than extreme power to do it's best. And the ribbon has a slight character (as does the big stat panel) that's always there. The Amazing has a higher output capability than I tend to want and I wouldn't get. But the freedom of amp choice is a huge difference for me.
I can run my mains with anything from a 2A3/300B, to SS. My currently hooked up are a pair of First Watt F1's giving me 4 channels of 10W each. That's more than I need for huge sound and all the bass you'd ever want starting to slope off as it enters the 20's. I have several decent examples of subs around and feel no need since I don't do any videos, only music.
It's really fun to see folks trying entry level with the simple cardboard attempts. Just wish more could hear the next steps up and how truely competitive they can be with anything, anything you can buy.
EV3
I certainly agree with your points, primarily that panel speakers are going to be more limited in terms of dynamic expression, and that they require robust and expensive amplification. That is just the nature of who they are, and if you want that sound that is the road you are going to have to travel. Yes, conventional speakers in an OB arrangement are more amplifier friendly, but there is an associated trade off in terms of low level resolution.
But some of this is about favorable equipment pairings. I have always believed that high efficiency speakers with SET amplification is capable of delivering electrostatic like resolution but with better macro and micro level of dynamics. In the past I have used a variety of single driver speakers as they are usually the most affordable way to do so. But my preference is for high quality horn systems, unfortunately I just cannot afford the good stuff at the moment. So when this used pair of OB speakers came available at a price I could swing, well I took a chance.
The problem I have with single driver speakers is that while they are authentic in the midrange, they tend to lack the harmonic density and proper decay patterns in the upper mids and lower treble. Music sounds proper in structure, but it doesn't have the texture that it should. The speaker I use has a coax driver, something along the lines of the Tannoy. Is it better? In most ways yes, but it is not quite as coherent as the Fostex 208 Sigma I have in my back loaded horns. Trade offs and priorities, there is just no way around them at the price points I can play at.
Now I have a couple of avenues to explore, and I intend to do them with these OB speakers. First, these drivers may not be as happy with a 300B SET amp even though they theoretically match up on paper. Or perhaps they will not perform in the way I think they should. I have a 33 WPC Class A battery powered amplifier coming, and in a few weeks I should have an idea of what it can do. I have heard this from Tannoy owners that their co-ax driver while theoretically efficient enough for SET prefers a bit higher power tube amps, or low power SS amps. The other option is to tri tri-amping them and getting rid of the passive x-over. With the battery powered amp in the house I can run it on the mids, the SET on the Radian horn driver, and the plate amps on the bass woofers. But I am going to have to source an electronic cross over and see how that pans out.
Lots of experimenting to do here, and I certainly do not have any definitive answers, nor are my opinions set in stone. All I have is my observations up until this point. I got my speakers on Dec 24, so I am very new to this arena. Needless to say, my opinions are subject to change.
Regards
Mister Pig
