MWalt
I alluded to it earlier, but in order to produce very deep bass in OB systems, you need a lot of displacement from your woofer. Where many of the pro woofer fall short is they have limited xmax. Doubling up drivers can help that situation. Trying not to recreate a spinal tap concert can also help.
The reason that limited xmax can be an issue is as you approach the published xmax, the driver will become increasingly non-linear. The Alpha, for instance, has a rated xmax of 3.8 mm (this is from memory) but somewhere around 2mm, the suspension becomes progressively stiffer to protect itself, but in the process, it's very non-linear.
For low level listening, you might never catch the issues. At moderate volumes, I found them unacceptable unless I used 2 per side, and even when I did, they didn't remain as composed as I like. That said, I'm also extraordinarily picky about low distortion bass. I got the but 16 years ago and haven't been able to go back to anything but low distortion bass. What some find pleasing bothers me.
What kind of sensitivity or efficiency levels are we looking at with these drivers in an OB configuration with a ribbon or Heil type tweeter?
