Open Baffle Epiphany!
Yeah it's a 10 inch in the same baffle with the Betsy. From their site: a Jantzen Audio 18 AWG Air Core
inductor is used with the Alpha 10" driver and the entire
speaker is powered from the main amplifier.
I guess Randy couldn't fit the 15 inch in that baffle. I would definitely bi-amp using a plate amp on the woofers like the $59 Dayton linked below.
https://www.parts-express.com/dayton-audio-sa70-70w-subwoofer-plate-amplifier--300-784
If you don't have a preamp buy the excellent $31 FX on Amazon and with Y cables you can share it's signal between the main amp and plate amp. Makes for a killer system for not much money. That's exactly what I'm doing with the Frugal Horns/OB woofers and loving every minute of it.
I have a preamp with two sets of RCA outs. One is high hain and one is low gain. would I hook that up using the Dayton you suggested? Just use the low gain output from the pre to the Dayton then to the woofers? And set the crossover so it sounds good?
That's what I would do. The Eminence Alpha 10A is 96 dbs so you won't need gobs of power. You will be driving both woofers from the one plate amp which will require doubling connections to it's single set of outputs. Making a case/frame for the plate amp will require a little diy. A wooden or plastic box with a cut out so the plate amp drops in will work and a pair of speaker terminals. No soldering if you go with these from Lowes. Just discard the plastic keystone tabs.
juno,
If you have an extra stereo amp and don't want to fool with a plate amp you can use that extra amp to power the woofers. Using a pair of these Harrison FMods between the preamp and woofer amp will fix the low pass crossover at the desired frequency.
Another option using the extra amp is this $75 Behringer CX2310 from eBay. You would need XLR to RCA cables ( very affordable from monoprice ) or adaptors as this is a pro active crossover. I'd recommend using the active just on the woofers while allowing the Betsys to run full range as they were designed to do with nothing in their signal path. That's the way they sound their best and why I would avoid a passive network with them. The Behringer takes the signal from the preamp, alters it's frequency and passes it to the woofer amp. I use my Behringer every day and love the fact that it has controls and connections for a separate subwoofer.
Kray,absolutely Wicked looking picture!.....bit of dough tied up there,actually a Lot of Dough,and look at his ceiling height,must be nice,I'm thinking those panels are 7 ft tall,maybe 8,and ceiling could be 20-30 ft,definitely an Absolutely Huge room to house his Mac extravagances!
Its almost like he wanted to create a (Wall of Sound') Horn Effect,early JBL/Altec(James B Lansing) style,certainly not OB,in the way I perceive it,but sure would be Fun to hear that system cranked,be like living the Maxell commercial in the arm chair!...Hang on here we go!
....I'm near sure those speaker components are JBL 15's,with the Silver dust caps,and matching 'Bullet' tweeters,I missed out on identical components in two Large console like boxes,with long spindly 6 in legs,all original.
...They supposedly gave the sweet,smooth Alnico sound 'with tubes',probably be worth a Crazy Fortune on Ebay,f you could even find any?...They would have the above 'Cobalt' Alnico mentioned magnets.
And,for certain,you would need at least Mac's to take the,nasty,Nasty 'EDGE',off those Hard Sounding Bullet tweeters,they sounded Absolutely Brutal with the wrong solid state electronics,most likley why they were for sale when I looked at a pair over 16 years ago.He auditioned them with a Sears receiver..Ow,that hurts!
EP Concert Kenny,currently spinning EMM Gryner.....The Summer of High Hopes...
Those B&C speakers look really interesting,with their unique magnet structures.
Sometimes you have to just bite the bullet and... 'Go For It'...on the other hand,can be risky proposition being a first adopter.
They certainly do look as if they would deliver good sound,and dynamics with their vented magnets,any reviews yet?
Still,I'm rather surprised to see a whizzer cone,instead of say a compression driver these days?
You would have to hear/Listen to a pair to truly know?....
EP Concert Kenny,tonight's concert AC/DC Live at River Plate......Kray its all your fault showing me those old JBL's,they brought back memories of the Grateful Dead's 'Wall of Sound'...I figure some Corona,& 200,00 South American fans ought to settle this urge for a bit!
On the bottom shelf are a couple of Yung plate amps in frame cases I made. The black one drives four Eminence Alpha 15A OB woofers ( two per side wired in parallel ). The other powers a conventional box subwoofer.
How would you power the sub of a H Frame with the normal fullrange/twitter sitting on top from same source/reciever? somethings not clicking for me. i.e. can i use my Sansui to feed the music to both fullrange/sub? with using this plate amp to power sub?
Several options to accomplish this:
A preamp with two pair of outputs - one pair of outputs feeds the full range driver's amp while the other feeds the woofer's plate amp
A preamp with one pair of outputs - using a pair of Y cables you can feed the two amps
A source can be directly connected to a plate amp's line level inputs via RCA cables. The plate amp will then send it's "pass through" signal to the main amp's input via it's line level outputs using RCA cables. ( note: the plate amp must have both inputs and outputs. The Dayton I linked above only has inputs )
The digital output from a CD player can be connected to a cheap DAC which feeds the plate amp powered woofers while the CD player's analog connection feeds the full range driver's amp.
A plate amp is the same amp that is built into subwoofers so whatever method ( including speaker level connections ) you use to integrate a sub into your system will work with the plate amp and OB woofers.
Plate amps can be confusing but they work like any other amp except they're mono and have a built in crossover. They're designed to be built into a subwoofer box so if used as a stand alone amp they need a frame or case. They come with one red and one black speaker wire that must be connected to a single pair of speaker terminals. To drive multiple woofers in mono the speaker wires are doubled up with a single plate amp. Stereo bass requires two plate amps. I've tried that but my ears can't tell the difference between mono bass and stereo bass.
Underside of a plate amp frame. Don't know if you can buy them but they're not hard to make. The red wire and black wire are connected to two speaker terminals on the left side.
Those are far from bass shy on there own. Had to turn the H frames wayyy down. Waiting on some boutique inductors before getting fancy with crossover board.
Thank you for all the suggestions. I wonder if I went with the passive option and wasnt happy I could add a 12" with plate amp later ? Or would that not work? I was leaning toward the passive route for simplicity and less clutter.
Well,don't know about the rest you guys,but I'll admit I was 'Openly Baffled' reading some of the above posts,trying to figure out as to who would admit to actually owning Monkey Coffin's! O.M.G!...
Ok,nuff Monkey Business!
....Yes,tonight finally get to watch AC/DC,Live in River Plate,been looking for this dvd for 4 years!....the South American Fans have so Much Energy!
You can certainly Feel it!....60'000 people singing along with you is Amazing!
Oh Yeah,going to see if these if 7 inch,vented woofers magnets can handle some power,had them running all day,they're Ready....good thing,cause We gonna Move Some Free Air Tonight!.
Corona time,Thunderstruck Kenny B,Rocking on in the Free World!
