Open Baffle Epiphany!
Thanks for the links to installing phase plugs.
However, my original question was about whizzer cones... not phase plugs. How would I install a whizzer cone? Would I cut out the voice coil cap as shown in the links provided? What is the whizzer cone glued to?
Or... would it be better/easier to install a phase plug instead of a whizzer cone?
Thanks.
Thanks.
I would listen to each driver individually and if they sound very similar I'd be more inclined to cut the whizzer off one rather than trying to fabricate one for the other.
Would not bother with a phase plug unless I knew the driver had a ragged top end. My Zeniths sound very smooth without a phase plug and play fairly high without a whizzer cone.
I wish I could get a frequency scan done on these 8 inch Heppners. Did you ever have your Zeniths' frequency range scanned?
And you run the Zeniths without a helper tweeter?
I don't think I'll be cutting any whizzer cones off. I'll just pray another Heppner with a whizzer cone shows up on eBay.
I use tweeters with my Zeniths to add some sizzle but others don't ( like Mr. Glow-in-the-dark ). They do a good job covering the highs on their own.
I'm not a fan of whizzer cones though I'll have to admit the speakers that I heard with whizzers were pretty shabby to begin with.
You did say you have one coming, correct? If so...
Before you dive in I think you should do an A/B comparison between the two. You might not like what you hear...but .than again...?:dunno:?
Either way I'd be curious to hear what you think of the results.
I'm figuring that the one coming with the whizzer won't sound bad, given that the ones I have without whizzers sound great to me already. I will indeed be doing a direct A/B comparison when it arrives... I think on Friday. I'd be surprised if the whizzer-ed cone sounded worse. I'll report what I find out.
I am enjoying reading all of the stuff about everyone's adventures with OB. When the Eminence Alpha 15A came on sale at PE, it was time to give it a try using MJ King's great site of OB projects. I first did the tall OB and used 2 Electrovoice LS-8 running FR for my HF. It was pretty good but my LS-8 aren't well matched and I was getting a lot of overlap in the bass. Then I built the stock shorter version using the Fostex FF85WK. It was nice but I'd like the stereo image to be a little taller so I built these. By changing the baffle I may have screwed up the response but they sound pretty good to me. (no measuring capapbility here) The downside is I'm not able to use any of the restored vintage tube amps I own and haveIMG_0498.JPG IMG_0499.JPG to use SS. Any way I can integrate a tube amp for a least the HF? Thanks for any and all suggestions. Keep up the great topic.
I am enjoying reading all of the stuff about everyone's adventures with OB. When the Eminence Alpha 15A came on sale at PE, it was time to give it a try using MJ King's great site of OB projects. I first did the tall OB and used 2 Electrovoice LS-8 running FR for my HF. It was pretty good but my LS-8 aren't well matched and I was getting a lot of overlap in the bass. Then I built the stock shorter version using the Fostex FF85WK. It was nice but I'd like the stereo image to be a little taller so I built these. By changing the baffle I may have screwed up the response but they sound pretty good to me. (no measuring capapbility here) The downside is I'm not able to use any of the restored vintage tube amps I own and haveView attachment 1426287 View attachment 1426288 to use SS. Any way I can integrate a tube amp for a least the HF? Thanks for any and all suggestions. Keep up the great topic.
Welcome to AK! Great job on the baffles!
Welcome to AK,tubav,I like the shape of your OB's......OB's are sure fun to experiment,try different drivers with,our ears tell us a lot.
Looks like I see a pr of Mono Blocks there,are they your design?
Let us know what you think of the Whizzer' (Wizard?) pair hnash?
EP Concert Kenny,tonight's concert,Toronto Rocks...
The mono blocks are Heathkit W3M from the 1950's. A very dear friend (who's sadly deceased) did those for me. Originally they came in 2 chassis and I built the wooden frame that combines them into one unit. I tried them but they made a funny clicking sound driving the OB's. They sound wonderful on all of my other speakers. I also have a restored Eico ST-40 that is terrific. I'd like to somehow integrate one of these into powering at the HF portion of these OB.
Ooc, has anyone played with the Dayton Audio PS220-8? I'm still super interested in the Tang Band W8-1808's, but at less than half the price, with a few glowing reviews, the Daytons are tempting me. I have the low end covered in spades, so lack of bass doesn't worry me much. And I have heard they can run a little "hot" in the HF, but I do have an EQ for that, if needed. (I kind of prefer that sort of sound signature.)
:thumbsup: Nice builds. Using a tube amp for the HF will require bi-amping and your'll need an alternative to your passive crossover.
Any suggestions on a simple and/or economic way to go with bi-amping and use either my Heathkit W3M or Eico ST-40 for HF? I have 2 or 3 SS amps for LF. Up to now all of my speakers have been passive so this is a new direction for me . Thanks for any and all suggestions.
see page 141
On a Facebook open baffle group someone suggested Rockville 15 or 18 inch drivers give better bass response than the Eminence Alphas. Has anyone tried the Rockvilles? $80 a pair on Amazon.
Car woofers and the ones I looked at had low Qts which is not a desirable trait for OB's
Do any of you have any standard Betsy speakers that you want to sell?
I just tried to order some and was told that the standard Betsys would not be available again for 4 weeks.
If you do, please contact me... thanks!
