So I'm gonna repost this from the DIY forum since I was told it might get more traction here.
"So as you might know, I built a very simple set of OB FR speakers. The driver used was the Dayton PS220-8. The mounting was a simple piece of faced plywood. I have an EQ and it's got an active crossover and sub out.
I ran the PS220's with my Yaqin MC13S amp. The EQ splits off the signal to the sub out and I have the crossover for the low pass set to around 100hz. Obviously this mean that the sub is getting 100hz and below, but the PS220's are getting the full signal.
I just received 2 Eminence Alpha 15A, per Poultrygeist's recommendation, to integrate with a new set of panels. The wiring for that is super simple. I run from the amp to the PS220's, and then run parallel to the Alpha. with a 9.0mH inductor in the positive path to the Alpha, limiting it's FR down to around 150hz @ -6dB. Shallow slope, but it seems to work really well.
Now, I've been discussing the process with a fellow enthusiast who owns the PS220's as well, but has not used them in this manner. I did state that the PS220 lacks a slight bit at the tippy top end, as I imagine almost all FR drivers do. This isn't even something I thought I'd notice, but there it is. Perhaps it's actually because I AM doing critical listening, that I notice it.
In any case, I have been discussing with him the possibility of adding a tweeter of some kind, just something to light up that last bit of sparkle. We discussed a few different contenders, but I was most interested in the HiVi RT2C planar tweeter;
https://www.parts-express.com/hivi-rt2c-a-planar-isodynamic-tweeter--297-406
The way my system is set up would alleviate the problems caused by what some have labeled a narrow horizontal field. It's One recliner set in "the triangle". It's meant for one person to really LISTEN to music. So there are no off axis worries.
I was perusing eBay while at work, (group home overnights, lots of downtime), and found a pair for a very good price. In casual conversation I mentioned that if they were still up for sale when I get paid in a couple weeks, (group home overnights, terrible pay), I'd be picking them up to give a 3 way design a whirl.
I apparently did not understand his enthusiasm for my experimentation, as he immediately offered to purchase them for me "in the interest of an affordable high quality design". His only requirement is I document the build for others.
I accepted. $160 worth of free planar drivers is nothing to sneeze at.
So now my conundrum. I know the values of the caps I need for the high pass to the HiVi planars. I have the inductors for the low pass to the Alphas. I want as much of the full range to go to the PS220's.
What I don't know is how to wire this whole mess for either a 4 or 8 ohm total load, (both have taps on my Yaqin).
My first instinct was to just go Alpha/PS220 parallel, and then to the RT2C serial. But I have been told this is bad for REASONS.
So what now? there are, in fact, 3 way speakers. I SEE'D EM'! How do I make mine do the thing?"
Since then, I have ordered an 8 ohm dummy load transistor. My engineering friend says this is sub-optimal, and I'm aware it just "wastes" 25% of my amps output. But I can't really afford another pair of drivers, at this time, and want to see how the design works with the HiVi in place. If I like it, I'm going to have to get different baffles cut and go with either 2 more 15", (which honestly aren't even needed), or 2 more 220's, (same situation), or 2 more HiVi's, (well, you get the picture). I could run the whole thing as a 12 ohm load, but it seems like that's going to put me in roughly the same situation as adding the resistor?
Anyway, any help would be appreciated.
