Open Baffle Epiphany!
Here's the Zenith 49CZ802 top which rests on the H-frame Alphas. The Beta 12LTA once occupied the same baffle but were sold to a friend after hearing the Zeniths. I currently use the Bottlehead 2a3's to power the Zeniths as they seem to extract the greatest amount of detail.
My only regret is that I should have held off posting about the incredible Zeniths until I bought a second pair. They used to be plentiful and cheap but now if you're fortunate enough to find a pair they're anything but cheap.
What is the rear firing tweet on those?
@Poultrygeist, what's your XO point for the tweeter? Any idea where the CZ's roll off ?
The Zeniths and tweeters are powered by the same amp. I use a 1.5uF cap on the tweeters while the Zeniths run full range. The woofers are powered by their own amp and use an active.
The rear firing tweeter is a Realistic super tweeter.
I've read some concerns about beaming with using 12" drivers (from about 1300Hz up). However, Mr. Glow says the sound improved by removing the tweeters.
Any concerns about beaming? Has that been addressed?
Has anyone ever done a frequency sweep with the CZ's and checked frequency response and off-axis response?
Suppose they DO beam...worst case, does that mean the sweet spot is much smaller and that I need to point the speakers directly at my listening seat?
Edit: Didn't mean to hijack. I think I'll continue posting this thread https://audiokarma.org/forums/index.php?threads/the-magnificent-zenith-49cz852s.785729/page-2
Poultry, how do those Realistic add to the sound? I'm interested in adding a pair of super tweeters to the backs of mine, if for nothing more than to get a balanced impedance load. I was going to go the resistor route, and even bought a pair, but I get guilty about throwing watts away as heat.
Although, someone on a guitar forum was talking about using a dummy load resistor to get their amp up and working for a gig while they waited for a new 2nd driver in the mail. Another poster said a dummy load resistor could actually be preferable, due to the fact that it's a consistent impedance, as opposed to a driver. That's where the science and any possible benefits go over my head.
I had toyed with the idea of getting another set of Alpha's, but the 24"x48" baffles already take up a lot of room. I'm not going for WAF, but The baffles to house 2x15" drivers and still have room for an 8" FR and a 7" planar would be ginormous.
I was thinking something small, like the Selenium ST200, or possibly a pair of the Skar Audio VX1-ST. Both have a higher efficiency than the rest of my drivers, but since they'd be back firing I would imagine it would mellow the SPL.
So been loving my Open Baffles which consist of the Audio Nirvana 15" classsic on top and the Goldwood 1858 on the bottom crossing at 150HZ using the Marchand XM9 crossover. I have a new project in mind after seeing a pair of Linkwitz Orion speakers using the peerless XLS drivers in OB. I have also read a bit about OB subs. I have a pair of the peerless 12" XLS drivers setting gathering dust and I wondered if anyone here could help with the size for an H-Frame to try the drivers in for sub duty only (40Hz and below)
Been wondering how the OB would sound with the 15" AN Classic at FULL range (It was running 150 & above) so spent a few minutes this morning taking out the XM9 and to my surprise it is sounding DAMN GOOD. Only Crossover in the line now is the crown XLS1002 on the goldwoods.....................Guess now I will have to play with that I see a lot of folks like to cross over close to 200. I dont want to have any audible vocals on the goldwoods as that never sounds good IMHO. Added a Pic they have since been veneered / painted
I have an inner ear issue that is affected by certain freq. Testing proved that having the drivers tilted back maintains a very good soundstage while allowing me to listen at pretty much any level and any length of time without my inner ear issue acting up
I hear you. I've used an active crossover on the HF and LF but in doing so lose much of the tube amp's magic. Now days I use an active on just the woofers while the full range speakers run full range.
Sounded quite good, I did notice though the 1.5 WPC SET amp on the 15" AN was being forced to move the driver with lower Freq. I thought I might be asking a bit much from a 1.5 WPC amp to start and stop a large cone
I have an EL-84 based amp that can play in 2 modes 6 wpc or 13 wpc on the way it also allows for Feedback adjustment (allows tailoring the sound a bit) it should have no problem controlling movement of the cone. The heavy accordion style surround does not allow for much in the way of cone movement I thought things would get a bit muddy / harsh at times perhaps the Little Darling parallel was getting into clipping. I dont want to push my luck those drivers are 1400.00 now
I run some vintage 8" Heppner speakers in OBs. I've been thinking about adding a tweeter to bring out the highs that these Heppners just can't quite reach.
I've read that some of you have added a tweeter using specific capacitors of certain values. What cap value should I use? Or,... how do I determine what value(s) is/are the right ones?
Finally, how do you wire in the caps? I've never done this before... so some help would be great.
Also, perhaps suggest some reasonably priced tweeters to consider if I do this project. I've seen a few tweeters that have a capacitor included with them, such as here: https://www.parts-express.com/pyramid-tw18-bullet-horn-super-tweeter-pair-aluminum--270-100
Many thanks.
Selecting the right cap value is usually done by trial and error. I keep a bunch of different value caps ( below 1.0 uF and up to 2.0 uF ) on hand and connect them with alligator clips. I listen until I find the one that's gives the right amount of HF. It can often be a matter of individual taste.
1.5 uF IMO seems to be the sweet spot for the Eminence ASD1001 tweeters paired with the Zeniths. I believe those tweeters are around 100 dbs.
Selecting the right cap value is usually done by trial and error. I keep a bunch of different value caps ( below 1.0 uF and up to 2.0 uF ) on hand and connect them with alligator clips. I listen until I find the one that's gives the right amount of sizzle. It can be a matter of individual taste.
1.5 uF seems to be the sweet spot for the Eminence ASD1001 tweeters.
Thanks for the reply. When connecting up the capacitor, what do I connect the two ends to? Referring to the tweeter I linked to, I read that one end goes to a "terminal." What terminal? And then I read that the other end goes to the positive speaker wire.
Again, I'm very green on this and need some guidance.
Tweeters usually have two male tabs or terminals ( + and - ). The tab marked with a red dot is positive and you'll need these unless you plan to solder them to the amp wires. Probably the blue size.
