Open Baffle Epiphany!
Well, I've been in discussion with @Nixxuz while he built his OB's and have now the following caps:
Tweeter: Russian K75-10 3.3uF + FT3 0.1uF bypass
FR driver: KZK White Line K78-34 33uF
I've a pair of massive Mundorf L200 8.2mh 0.61Ohm inductors I mistakenly bought when redoing crossovers for another speakers (on going project) to use on the sub.
Funnily enough I've settled on a different approach due to lack of faith in my being able to build the baffles to the level I'd like. I'll be buying 2x 15" car sub enclosures and affixing the front baffle with 5x wood screws and liquid nails. A pair of screw in rubber feet on the bottom of the baffle to angle it up slightly.
I'm going to use this tweeter on the back of the baffle pointing up at the wall: https://www.parts-express.com/dayto...-transformer-automotive-tweeter-pair--275-195
Dayton PS220-8 about head height from the sitting position and Eminence Delta-15A sub drivers.
I think this should work out quite well and will look good despite my lack of wood working skills.
Suggestions welcome . I already have the Dayton PS220-8 drivers, the capacitors and inductors though.
I'm starting to reconsider the Eminence Alpha 15A's, and have started looking at the Goldwood GW-1858's. I have of course read, here and elsewhere, that the 15A's would benefit from an H-Frame. So maybe I'll give it a try and see what happens.
Edit: well that took less than 24 hours...
For the eminence tweeters I have for my open baffles I am using the 1.5uf Dayton caps. I want to play around with other varying caps to see if I can open them up a little more, but not overly so. What would be the next one in line that I should look for? A 1.0uf or ?
My experience has been that if you go a little higher in capacitance, what will come through will be like moving a window off the highs to the right. For example less of the lower part of the vocal. More of the symbols. Subjectively it may "sting" the ears more. It can seem louder. If you go down, it will be like stretching that window to the left, picking up just a bit more of the spectrum (towards lowee tones). Going a little lower may sound a little less obtrusive. I am just ad libing on the spot. Since I haven't been watching this thread for a long time, I don't know what model of eminence you are using. Another way to play with this stuff is to buy the $80 Berhinger active crossover (provided you have another spare amp) and then you can tweek the crossover on the fly while you are listening.
Cap values for tweeters which run off the same amp as the mains can be very subjective.
It's best to keep a variety of different value caps on hand so you can go with the ones that sound best to you. Listen for sibilance where there's too much of the sssss
sound. If that's the case the tweeters are too hot and need padding down with a lower value cap.
Using alligator clips on the cap ends allows you to swap out different values.
Got it. But what variety of caps should I be looking for? What number values?
My tweeters are 104 dbs while the Zeniths I'd estimate at 97 dbs. It's always preferable for the tweets to be more efficient than the mains.
I tried 1.0uF, 1.5uF and 2.0uF. The 1.5uF seemed best.
I’ve done both and the Alpha’s in h-frames were definitely more effective at conveying palpable and tactile bass notes than when on a flat baffle...and when I tried them on a flat baffle I had two per side.
I just got most of the supplies needed to try my next set, which will be dispensing with the Alpha's entirely and going for dual 8" subs per side in a slotted port design, with an extended baffle for the FR 220 and a planar tweeter. The enclosed 8"s will be run off a hefty SS amp, and the rest off my P/P tube amp. The Alpha's are OK for what they do, but even in H frames they just don't go low enough.
A slot loaded open baffle? Or a slotted port in a cabinet? The slot loaded OB subs are trick and I have four Acoustic Elegance IB15’s I’d like to try that design with.
Regarding the limitations of the 15A’s...I totally agree. I used a pair of sealed 12” DIY subs (Dayton Titanic) with my 15a’s and allowed them to play up to around 60Hz (it may have been higher than that, come to think of it) which is where I had the crossover set for the 15a’s to roll off since they are easily pushed to over excursion if you throttle them too much and allow them to play unfiltered on the bottom end.
H-frame Alphas are not subwoofers. They'll reach 40hz which covers a great deal of the acoustic jazz I listen to. I augment them with a pair of bucket subs which are true subwoofers and measure flat from 25hz to 100hz.
Would these 12" Tannoy Gold drivers be a good candidate for an OB installation?
Explore what box they would work in . Make your open baffle the dimensions of the front baffle for the recommended box. Try them open and if you find they do not perform well you already have the first part made for a box. Also if there is any baffle step compensation in the crossovers you will be a step ahead. Let us know how they turn out.
