Poultrygeist
Lunatic Member
If you can solder at all it's much easier to solder the cap wire end to the terminal and it's other end to the wire from the amp. If you don't feel comfortable doing that then crimp the female connector on one end of cap and on the other end you can do a male to a female connector. A butt splice connector will also work to connect two wires together without soldering.
