Open Baffle Epiphany!
Here's a close up of the Zenith 12" cone. Notice how the ribs extend all the way to the edge. I painted my gaskets flat black as they were an ugly beige. My 49CZ802 and Mr Glow in the dark's 49CZ852 are exactly the same. I can only assume that all of the 800 series are the same and maybe others.
The best OB woofers are those with loose cones ( Qts 1.0 and above ) that can move lots of air in free space. Tight cone woofers with low Qts that work well in box speakers can't cut the mustard in open baffles.
Yeah, the Magnavox consoles are not closed boxes. They will work pretty well at least until I can create a PureAudioProject Quintet clone with total of eight 15" Eminence woofers. :rockon:
mjw,
I know shipping from the US to Australia can be expensive but there's another option that you might find locally. These 16 inch woofers I harvested from Sansui SP-X9700's left on the curb and they work very well in open baffles. The Japanese Kaboki speakers from the 70's had large woofers stuffed into small boxes and I wouldn't be surprised if many of those would also made nice bass in free air.
mjw,
Lovely looking drivers those. I'm set on is the Magnavox for bass though. If they don't live up to expectation I'll use the Eminence Alpha-15A drivers instead... If still not happy an SVS sub should do the trick. 17" wide is as wide as the baffles can go due to space restrictions.... A shame as those 16" drivers were made by Coral and are 100db efficient.
Got our baby back from the hospital yesterday. Haven't had much by the way of sleep yet. My wife has said she probably won't let me build the speakers for 6 months or so. Just not enough time (or sleep) :(
Poultrygeist, how are you powering your OBs? I know you are bi-amping them with the H frames, but are you running the tweeters and the zenith's off of the same amp? Also what amp are you currently using?
I've been bitten pretty badly by the OB bug, and have been scheming on building another set, and am just curious as to what you're currently using.
I have two OB systems in use at the present ( Zeniths over H-frames and Lowthers on flat baffles ). Today the Dennis Had single ended EL84 is driving the Zeniths and it's tweeters while Bottlehead 2a3 mono blocks power the Lowthers. Tomorrow that could change as I enjoy swapping these amps. They are pretty much interchangeable as the EL84 makes around 4 watts and the 2a3 is rated at 3.5 watts. Both are power amps so I also swap between tube and passive preamps. Both systems use active crossovers.
The woofers are powered by class D TPA3116 and TPA3118 amps. The Alpha 15A's are 97 dbs so they don't need that much power.
How loud do the zeniths get with only 4 watts? I don't need ear shattering volume, but I do like to get immersed in volume every once in a while and an curious about this combo.
In general, I agree, but there are exceptions depending on how you do it. One version of the Linkwitz Orion used this Peerless woofer, Qts = 0.23.
https://www.parts-express.com/peerl...Uxqj7nTNfEMQOYqz_4X-pUCDE5mrdC-hoCFAkQAvD_BwE
Lots of EQ in this model, which I prefer to avoid.
I rescued a 1957 15" Magnavox full range out of an old beat up mono console about six months ago. I put in an open baffle and hooked it up to my son's guitar amp, he was amazed at how nice the thing sounds.
I need to find some tall rubber feet for the Zenith baffle. I did this with the Tang Bands and liked the fact that the top baffle was decoupled from the H-frames.
I don't know if you were asking for options. If so, I've found laboratory "rubber stoppers" work well for this (I use them if I stack something on top of an amp, for air flow). Size 6 stands 1" tall. Chart below shows white ones, but black are more commonly available.
When something larger is desired, I've used hockey pucks (3" dia x ~1" thick).
