Open Baffle Epiphany!
Alright. After watching this thread and finally reading through it, I decided to give it a try. Picked up a pair of Zenith 49CZ903's, a couple of suitable boards and shelf brackets at the local hardware big box and cobbled them together in about half an hour.
I have a great little Magnavox 196 single ended amp that I decided to use to power them. I ran the output from my Yggdrasil DAC through an Audiocubics "preamp" then over to my Monitor Audio subwoofer. From there, on the low level outs, I ran the signal into the Maggie. I've got volume control from the great little Audiocubics unit. Found a suitable crossover point (by ear) on the sub and have been listening for a few hours.
Quite a revelation. :music:
My normal system is a Rogue Audio Cronus Magnum feeding a pair of Totem Hawks. Love the sound of that system, but this little barebones 2 watt open baffle system is loads of fun! Of course, low end is coming from the dual driver Monitor Audio sub, but the combo is quite impressive. The Zeniths are ....articulate. Very clear. Maybe slightly shouty at higher volumes, but that may be due to them needed some run-time on them (or a totally inappropriately sized baffle ). I don't know how long they sat up. The little Maggie has plenty of power to push these way past conversation level. Soundstage is HUGE.
An L-pad will attenuate those highs a bit with a wee bit of clarity loss. Or heck, even a resistor up top. Nice going.
Excellent. You can bring them out further from the back wall, sit closer and still get the full effect.
I found with flat panel OB's that the placement really affected the highs and lows, more toe in accentuated the highs and less boosted the bass. I ended up adding a small top and sides to mine so they are now more or less really shallow open box's. That seemed to really help and they are much less picky about placement this way. I spent every bit of free time for almost a week messing around with baffle size and placement and found personally the baffle size not to matter all that much, but then again I'm really new to this and am am still in the infant learning phase, so take what I say as such.
My only regret is I didn't try OB's years ago.
As indicated in posts # 3086 and # 3091 from last week, I’ve been playing with a pair of Paradigm PV-160 in wall/ceiling speakers as open baffles.
Yesterday I made up temporary cardboard baffles from a spare tri-fold display board. The board was 3’ tall, 4’ wide. I cut in half into two pieces each 1.5’ tall, and cut 7x10” rectangular hole in middle of center panel of each to fit the frame of the PV-160 speakers. Center panels are 2’ wide (~4x the width of the woofer). Wings are 1’ wide. As this is temporary, I used double-sided foam mounting tape to hold the speaker frames to the cardboard baffle. See photo below.
One issue I am unsure about using the PV-160s is that, as a ready-made 2-way wall/ceiling system, there is a frame surrounding the integral baffle the drivers are already mounted on, and this frame has a lip on it that stands about 5mm above the integral baffle (this lip helps to hold the removable grilles, and forms a flange for wall/ceiling mounting). The integral baffle plate and the cardboard baffle end up being co-planar, but that 5mm-tall lip stands between them. I don’t know if this has a sonic effect, but the fact that by the mid 1980s better speaker manufacturers were eliminating cabinet projections above the front baffle makes me think it might.
Anyway, playing them on the dining room table, as before (post # 3086), there was a significant change in the sound of the PV-160s with the added baffle. Much more of a resonant, full room-filling sound, with significantly increased lower frequencies, and overall louder. The change was noticeable when I first tried it with just one speaker fitted with a baffle, and increased with both done. The increased presence of the bass was such that at first I felt it was too pronounced, and perhaps somewhat flabby, and began wondering if I had acclimated too much to the baffle-less setup, but then I recalled I had left the bass tone control boosted from the prior setup. Once I returned that to flat, the balance was more natural. After more extended listening, I think there is still a little too much resonance/slop at lower frequencies, and from touching the baffle while playing, it seems the flimsy cardboard baffle might be contributing to it. That will presumably disappear with a proper build. Placement with the baffle directly on the table probably enhances bass response as well.
Next I moved them over to the living room where I have my main system is set up, where naturally I have more listening experience. Initially I tried placing them on chairs to elevate the drivers, but could not support the floppy baffle, so I had to place them on the floor, with only a modest separation, as shown in this photo. It is not ideal for dispersion, but it is what I could do with the space and limited time I had.
I was able to play them along side a pair of DCM TW1s that you can see to the left and right of the Paradigm PV-160s. The TW1s are supplemented by a 10” NHT sub. Not a fair comparison, I agree, but I am very familiar with the sound of this system, so it was useful for me to compare it to the PV-160s. I fed each set up from a common source but different preamp/amp.
The PV-160s sounded quite good in this set up. They were quite transparent (simply disappeared) and played very sweetly. They were lacking in the lower bass in this room (but see further testing below). What I noticed most was that whereas the sound was fairly tightly localized in the space between them, they admirably filled the space behind them, creating a very pleasing fullness in the room. In comparison, the TW1s had a much broader presentation, with sound spread beyond the space between the speakers, but did not have the depth of sound field that the PV-160s displayed (i.e., the TW1s were more 2-dimensional in comparison). I take it that this is one of the major strengths of an open baffle.
As to the narrow presentation of the PV-160s, I did have them placed rather close together (as well as low on the floor); afterwards I moved the other speakers partly out of the way and separated the PV-160s further. With this, the breadth opened up very nicely (not as impressive as the TW1s, but that is their forte), but because the PV-160s no longer had as clear a shot to the wall behind them with this particular positioning, the illusion of depth behind the speakers was lessened.
Lastly, I hooked up the PV-160s to what was driving the TW1s, so they would have the benefit of a sub. I did not try to tune the sub to the PV-160s, just use it the way it was set for the TW1s in terms of overall level and crossover points (75Hz). The PV-160s now sounded much closer to a proper balance (or my perception of it), but some fuzziness/flabbiness at low freq was evident when there was a lot of low freq content. This likely has at least one if not two sources: the sub needs to be tuned properly to the PV-160s, and a sturdier baffle is needed.
Overall, I’m convinced that the excitement about open baffles is justified, even if the ones I’m working with at the moment are far from ideal. And I haven't even played around with overall size, wing size, or angle. I’m planning to build a better but smaller, modest-sized set of wood baffles for these sometime in the months ahead, for use in a smaller room, and see how it goes from there.
Many thanks to all contributors to this thread; it has been very informative and interesting.
Yeah welcome to the dark side. I've only been in the OB game a few weeks, but I'm already scheming on building another pair.
Well crap, I just bought a pair of 49cz802's I paid a bit more than I wanted, but it was less than I've been seeing them go for, I just saw a pair just go for almost $300. I'm super excited to hear what everyone is talking about.
How shallow are you talking? Would a few CM do? Could you provide a photo?
I can't get a picture at the moment, but they are about 6 inches top and sides with a larger base for stability. I don't know how small you could make them and still get the desired effect. I was just shooting in the dark and decided to try it. My idea was to get another reflection point so I didn't get cancellation. I'm sure the larger wings on the Wild Burro design would do the same thing, I just didn't have that much plywood lying around to do it exactly like his so I only had 6 or so inch wings, and so I think I ended up crudely reinventing the wheel a bit, but I'm happy with the outcome.
I'm waiting for a pair of 49cz802's to come in the mail and I'll have to build another set because the EV's are only 8" speakers and I never really finished them past crudely putting them together so I wouldn't want to even if they did fit. I'm really curious to hear the difference.
Mmmm, 15cm isn't bad. Might go a bit deeper than that I think. Seems a simple enough way to do things. Will use little L brackets to hold everything together :)
Here is some good info about pros and cons of wings.
THE PERILS OF HAVING WINGS
There’s only a couple more aspects that we have to consider before embarking on the final design of our Open Baffle. One is should we have ‘wings’ folding back from the sides of the baffle? The simple answer to this one is ‘yes’ with a proviso.
Folding back the sides of the baffle obviously extends the baffle and helps lower the cut off frequency. It is especially useful for increasing the lateral path length and making it considerably different to the vertical baffle dimension, all of which helps to ‘blur’ and smooth out the baffle step in the frequency response.
In addition these side ‘wings’ increase the baffle’s stability. How else are you going to keep it standing up? Watch out, however, for the reflective standing waves that are set up by these folded sides. Think of it in terms of a box with the rear panel missing. What you will hear, with deep ‘wings’ is a hollow, resonant honky nature to the midrange that is really very unpleasant, especially on vocals and piano. You would be better off putting the drivers in a box rather than have deep side wings – at least then you could include some interior absorbent to reduce the effects of the resonance.
So keep the side folds shallow and taper them so that any standing waves don’t occur at just one or two audibly obvious frequencies. The attraction of tapering the ‘wings’ in a two-way system is that the bass unit receives the maximum benefit from the extended baffle while the midrange unit, which ‘sees’ the narrower section of the taper, is more ‘open’ and so suffers less reflection.
source: http://www.hi-fiworld.co.uk/loudspe...udspeakers-open-baffles-and-bass-part-15.html
Well, I begin measuring and cutting timber tomorrow. Bought extra wood. Doing H frames after all. Will still use Dynamat Extreme on the inside of the front baffle. Going to be quite heavy when done :)
Will use whatever is left over to do some arm boards for my JVC TT-71 turntable. Get the modded 12" Lenco L75 and maybe 10" Denon DP70M tonearms mounted ;)
A quick question, will there be any negative effects having my Zeniths also in a H frame as well as the Magnavox drivers?
Going to use the bullet tweeter pointing up at the ceiling to avoid phase issues.
Interesting design with concrete baffles
