Open Baffle Epiphany!
I don't know if you were asking for options. If so, I've found laboratory "rubber stoppers" work well for this (I use them if I stack something on top of an amp, for air flow). Size 6 stands 1" tall. Chart below shows white ones, but black are more commonly available.
When something larger is desired, I've used hockey pucks (3" dia x ~1" thick).
Thanks. I'll probably go with these. https://www.parts-express.com/penn-elcom-f1691-rubber-cabinet-foot-1-dia-x-1-h--260-774
Hockey pucks are a rarity in the south. I've never even seen one up close.
Mmmm, checked the back of my Aurum Cantus F620 speakers today. They only reach down to 35Hz.... Assuming my OB's can get to 40Hz once complete, there's a fair chance I won't hear the difference..... Heck, the big 15" Magnavox may actually produce more bass while only having a differential of 5Hz which means it would sound better on bass anyway..... Got to try it I guess.
Looking into baffle roll off. Right now my 8" FR driver, the PS220-8, is sitting in a 12" baffle. I've got some cutouts from when I made the H-frames for the Eminence 15A's laying around. I'm wondering if sawing those in half and then using them to extend the baffle to the right and left of the PS22's would offer any correction? It would effictively increase the baffle width around the 220's to closer to 20".
Any thoughts?
Roughly...
Well, I'm giving a shot regardless;
And behold! It's doing...something. I did both and find the centering and separation are better. I was getting some smearing before comparatively.
Interesting diy OB's for sale. The Fane full range drivers look quite interesting. The 12" Fane Sovereign 12-250 tc is 100 dbs efficient but can take huge power.
Anyone tried a Fane?
https://www.usaudiomart.com/details...nch-fane-sovereign-12250tc-fullrange-drivers/
Looks like they've already sold. A mate of mine picked up a pair of vintage, probably DIY speakers which has a big Fane driver in it. While I've not heard it myself he reckons it sounds pretty rubbish.
I've only used FANE speakers with Guitar amps, and the old ones are really good in that application, I would guess that if the speaker your friend has doesn't sound all that good, it's most likely not full range.
That Fane Sovereign 12-250TC speaker looks interesting, I'd be curious to hear it in an OB too.
Seriously, I doubt that anyone would notice a difference between a pair of speakers which worked down to 35Hz and a pair which worked down to 40Hz (everything else being equal).
The size of the baffle will have the most influence on how much bass you get (if I'm not seriously mistaken).
Any thoughts?
Roughly...
Have you considered wings? GR Research uses two of different width...might want to look at how they do it in their OB kits.
Yeah, that's what I'm thinking. Unfortunately I won't have space for wider than a 17" baffle so I guess I'll just have to see how it goes
"Looks like they've already sold"
Would never be interested in a buying a JE Labs OB which takes so little effort to build. The Fane however got my attention as it gets some good reviews on diyaudio.
Me too - my open baffle experiments have been limited by the practicalities of the space I have available. On the plus side, I've been impressed by how much bass you can get from a 24" x 24" baffle, subjectively at least.
Certainly true with single full range drivers but once you add helper woofers baffle size becomes less important.
Yes, it would be lovely to have space to use larger baffles and even have enough space to let them breath properly. I can manage 3 feet from the back wall though it will only be a few centimeters from the right side wall and each will be hard against the entertainment unit. There left baffle will be open on the left with a stairway going down.... So far from ideal. Still, if my box speakers (highly regarded Aurum Cantus F620) work well in this space I'm hoping open baffles can too.
I did phase plugs on the Eminence Beta 12LTA to smooth out their somewhat ragged top end but the Zeniths have not one speck of harshness in the higher registers. I would not change one thing with the Zeniths.
Good to hear. I threw a pair of Zeniths into some simple open baffles and have to agree - they are highly detailed. Good enough that I want to experiment further.
