Open Baffle Epiphany!
Mmmmm, leaning towards C frame again.... I'd rather not risk the performance of the Zenith drivers as a full ranger. I'd rather sacrifice bass as that can be fixed with a separate sub.
I think I'll use speaker material on the rear of mine in order to try child proof it. No other reason to do so really..... Mmmm, maybe my wife would prefer cloth on the back too....
Trying something different... The egg crate is of the paper variety and has a light propping it up. But the idea is that it acts as a diffuser closer to the rear source. Thinking about making something a little more permanent and a lot more good looking out of wood.
Just won a pair of Zenith 49CZ803 on ebay. I want to use them with a pair of Goldwood 1858's in H-frames to fill in the lows. Can anyone provide direction as to the dimensions for the baffle to go on top of the H-frames and where the Zenith's should be placed?
http://www.quarter-wave.com/Project08/Jordan.pdf
You can build the inverted T baffle based on the dimensions of the H-frames.
My 49CZ802's fit in the same hole as my Eminence Beta 12LTA which is 11.07 inches. 11 inches may work?
I'll be making some baffles for my 49CZ860s real soon myself, maybe even tomorrow. I'll be watching for an update on your progress. :)
Planning to begin mine today. Haven't received the vintage drivers yet though I can at least get started on the frames. I'm keen as to try this. I also like my idea of these big baffles featuring in my babies earliest memories as dad's old B&W DM16 speakers are in mine.
I read last night that OB sound tends to stay in the room the system is in, and most can play OB's louder without the wife telling you to turn it down....
Will read through before getting started. Thanks again :)
In my books that's a pretty enormous incentive to go OB.
ost of my upgrades in the last few years has been about producing sound that I can enjoy without upsetting the missus ;)
Seems everyone is getting on board with the Zenith drivers. I suspect the price will go through the roof shortly as they become rarer. :(
Seems a bunch of us are jumping on the Zenith boat at the same time, I'll be curious to hear how they all come together. After I found the Zeniths, I ended up ordering the Apph mini 2013 for a little over $100, because the only amp I have at the moment is a Perreaux PMF 1150B, which is way overkill for the zeniths and I didn't want to risk blowing them with an amp that can push 200 watts at 4 ohms. It's coming from China, so I have a few weeks to get the Zeniths and to build the new OB's. I have a pair of very nice powered subs that I'm going to initially use with them, but I want to try the H frame Alphas when I get a chance. But between the new speakers and amp, I'm through spending money on stereo equipment for a little while.
My hope for all this is that I like it substantially better than my current setup and OB's and then I can sell some things and get the alpha's and an active crossover.
I'll be using L pads to limit power to mine.... My power amp is about 150WPC I think
I'd be VERY surprised if you don't run the Oldchen with the OB's. I'm starting to look at a 300B SET for my the tops of my semi-OB's. I have doubts I'm even pushing a solid watt into them most of the time. And, those little APPJ miniwatts look kind of fun for the price.
This seem to be what people are saying about the zeniths which is why I got the little 3.5 watt PC single ended amp.
Yep, My Yaqin MC13-S is pretty much overkill at 20-ish wpc. (At least that's what a member of a Yaqin enthusiast group measured.) Plus, I haven't gotten a chance to try a SET since I've done this build. With a Crown XLS1000 running the woofers, I'm free to try these flea watt amps. I might have to look into building one...
But all the upgrading these ChiFi amps need gets a bit daunting after I've already put more money in upgrades into the Yaqin than I originally paid for it. It's my first tube amp and kinda my baby now.
Might try directly from my Linear Tube Audio MicroZOTL 3.... That's 0.5WPC.
Hopefully that's possible with 3x drivers.... The Alnico 10" Zenith, 15" Magnavox and the 106db Skar Audio VX1-ST bullet tweeters. If not, it'll be through the darTZeel. Not too keen on buying another amp just now.
Began cutting everything to size. 2x baffle fronts done, 2x top, 1x MDF bottom (didn't buy enough wood wide enough for the base)
Baffle fronts
Tops + MDF base
Anyway, nice to finally get started. Just need my vintage drivers to arrive now. Taking their time coming from the US.
The single ended 4 tube APPJ/Miniwatt is a great match for the Zeniths. I've seen them as cheap as $89 on mass drop ( now called drop )
