Poultrygeist
Lunatic Member
When cutting wood if possible cut with the grain. It's easier and looks much better than cutting against the grain.
Do you prefer the 6v6 to the 6p1? I have never had an amp with 6p1's or 6j1 for that matter, and so I'm unfamiliar with the characteristics.Same 4 tube amp as the one above but 9 years ago I paid over $250 for it. Transformers are on top in this original version while the new version has them on bottom. Tube adaptors allow substituting 6V6 and 6AQ5.
Thanks, I'm very familiar with 6v6 tubes and have a moderate stash of them. I guess go ahead and order a couple of the adapters and see how they sound with the new amp.My up grade path for the 6p1 Chinese tube : 1. Russian 6p1p-ev 2. then with the adaptor I went with the 6AQ5, and 3. finally the slightly better sounding 6v6 also with adaptors. Someone called the Kenrad 6v6 "The Big Smokies" ( dark smoked glass ). 6v6 tubes are not expensive but most folks that hav'em lov'em.
FWIW Ken Rad stands for Kentucky Radio Co, a real asset to the war effort with all their defense contracts during WWII.
A diffuser it will have some effect where the wavelength is smaller than the object, and with those little cones/compartments being about 2" we're talking about frequencies of the order of 7kHz and above. Those egg crates will also have an absorption coefficient, but again they'll be effective only at high frequencies.Trying something different... The egg crate is of the paper variety and has a light propping it up. But the idea is that it acts as a diffuser closer to the rear source. Thinking about making something a little more permanent and a lot more good looking out of wood.
I would not put anything behind OB's to absorb or diffuse the back wave. The back wave is what makes OB's special. It's why OB's sound best pulled out into the room and away from walls.
I'm still getting the back wave, but it's diffused so it kind of cancels out that "smearing" effect that can sometimes make vocals seem off center. My room is not large, so 1st order reflections happen RIGHT away. This seems to dampen some of that response, especially in the more precise higher frequencies, while still allowing for a midrange bloom like you are describing. Perhaps, if I had a larger listening room, that effect would be different. But in this room, I've got hard walls only 15" from the sides, and 34" from the rear wall. Gotta make do until I can afford to convert a completely separate structure on my property into a dedicated listening room.I would not put anything behind OB's to absorb or diffuse the back wave. The back wave is what makes OB's special. It's why OB's sound best pulled out into the room and away from walls.
Ok, next question. I'm going to see how the new zeniths sound by themselves with out a tweeter and only a little help from my powered subs.
If I do end up wanting a tweeter, what are some good choices? Poultrygeist I see that you have the Radio Shack super tweeters and Eminence Asd1001b's.
I have been reading a lot about frequency cancellation when adding a tweeter to OB's, any thoughts, recommendations, or articles about this?
Generally one does want a rear surface that scatters the rear wave a bit rather than a smooth flat wall. You don't want a single dominant reflection IMO. I have found that a bookshelf (full of books) works nicely.
Mr "Glow in the dark" likes his Zeniths sans tweeters. .
If you can place the speakers 5 feet (or more) from the wall there is enough delay between direct and reflected sound that our ears can easily detect the difference.
The resulting reverberant field is more like a live setting.
His website is where I got the idea to run them without tweeters to see how I like them.
This goes with everything I've been reading about adding a tweeter to OB's to avoid frequency cancellation. What is it that you like about the Eminence besides it being extremely sensitive at 104.1 dB?If you decide to add tweeters I'd try Eminence ASD1001 compression horn tweets with a small wave guide firing upward or to the rear with a 1.5uF cap.
Also any opinion on horn cone shape?
