Open Baffle Epiphany!
I believe that these should sound open and possibly have less of an issue with sound waves cancelling each other out.... Hopefully give slightly better bass while getting some of that open baffle sound.
They'll be ever so slightly angled up. I've some rubber door stops to use as feet. I intend to saw about 3mm off the back feet.
Sadly much of my decision making with this is down to WAF.... I need my wife to allow them in the living room or its all pointless. I plan to use speaker cloth on the back of the cabinets to child proof them. I'm rather hoping they sound great even with the trade offs made.
I hope it works out for you, I did end up with something in the same ballpark as you with my first OB build, but I started with flat baffles and then a week of tinkering with it to get the sound I wanted led me to having sides. I also have a teeny room, so I was battling space too. Your sides look like they might be twice as deep as mine but hopefully it works out. I'm really curious to hear how you like it once it's done.
I figure that the consoles were effectively open back cabinets so it can't be bad.... It's what they were designed for after all.
I found this on Audiocircle which influenced me somewhat:
"I use a JBL D123 12" extended range,with a JBL 077 tweeter for the extreme high end. There in an open back cabinet,that has sides and top, with no sound absorbing material on any surface. It has a open airy sound of a true open baffle,but with more bass. In my opion, a great sound.- RUDY"
https://www.audiocircle.com/index.php?topic=108662.0
I rather expect that the true downside is that the build is more complex and more raw materials are required. I didn't factor in enough and ended up using MDF for my base.
Mmmm, since it's established that mine are really open back cabinets should I really be posting somewhere else or can I continue on this OB thread....
Mine no longer fit the category of open baffle or closed box though rather open back cabinet. Unfortunately Googling open back speakers brings nothing up except for guitar speaker cabinet information.
Naw, keep it coming me amigo. Lots of us are paying close attention. :thumbsup:
Yes, I'm hoping it works with my room. The right speaker will hard up against the entertainment unit on the left and within inches on the right.... Left speaker will be hard against the entertainment unit and open to the left of it. Rather hoping this will work in that situation. Likewise it needs to be stable enough not to be knocked over by either the dog, or our baby when she starts learning to walk.
Ok, I'll keep it coming. If successful it may be of use to someone. If not they can learn from my mistakes.
Well, ordered one of these to use with my open back speakers when done:
https://www.ebay.com.au/itm/Finished-3-5W-3-5W-Vacuum-Tube-Amplifier-6J1-FU32-Tube-Audio-HiFi-Power-Amp/163028396820?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=7b54a33687a24ba6b74f05f54600a9e5&pid=100675&rk=12&rkt=15&mehot=lo&sd=292506865693&itm=163028396820&pg=2481888&_trksid=p2481888.c100675.m4236&_trkparms=pageci:5b0504b6-b06d-11e9-979c-74dbd18068fb|parentrq:337d1e9f16c0a9cbf0cd5278fffeb430|iid:1
I've NOS RCA 5654 + 832A tubes coming. If it shows potential as a power amp (driven by my LTA MZ3) I'll get coupling caps upgraded, remove the volume pot and maybe get the output transformers upgraded to something decent. Hashimoto maybe?
The small footprint would be a winner with my wife... Likewise I can get money back on my darTZeel NHB-108B copy, assuming this can compete.
I figure that a low wattage SET is probably what the Zenith was originally paired with so it should work rather well.
Interesting little amp, I saw those when I was looking for a flea powered amp for my Zeniths, but decided to get the APPJ mini instead. I'd be curious to see how you like it. I'm still waiting for the little APPJ to show up before I can test out my 802's. I have a painting project in the shop that has prevented me from making the new OB's, but hopefully this week I'll be able to get around to it, and the APPJ should be here in the next week or so. I'm really curious to hear the difference between my mosfet powered EV speaker OB's and the tube powered Zeniths.
I like the looks of the FU32 and look forward to your impressions.
It's just my wife stopping me from getting mine over and done with. That and burst blisters on my fingers from the last one. Might focus on completing that one (left speaker,) before assembling the right.
I'll let you know when the OB's are done and have had a good listen. I believe that the drivers will need a few hours use to loosen up after having been in storage for so long. Break in will need to occur.
Ok filled the gaps in the first cabinet. 24 hours to set then sand back, cut holes for drivers and then varnish.
I didn't quite have time to finish assembly of cabinet 2 though I'm happy to say its all fitting together far more tightly than the first one :)
Getting plenty of blisters and cuts on my hands now. Soft hands as I'm an office worker....
On another note I really hope my Zeniths arrive soon. They've been scanned as in Honolulu, Hawaii for 7 days in a row now. Hate Pitney Bowes.... Buying through eBay has sucked since they started their own shipping.
Hi mjw21a,
You wrote:
If it shows potential as a power amp (driven by my LTA MZ3) ...
I have a pair of 49CZ open baffles and have been thinking about one day upgrading to a LTA MZ2. I've been searching the Internet for feedback on the Zenith 49CZ & LTA MZ2 pairing but I haven't been able to find anything.
Why wouldn't you just use the MZ3 as a power amp for the Zenith's? By all accounts it is a spectacular amp when driving high efficiency speakers.
When you get your speakers built, do you think you could give them a listen being driven by the MZ3? I'd imagine they'd make an incredible pairing and would love to get someone's impressions of the combination.
Good luck finishing the speakers ...
All the best,
David
Hi mjw21a,
All the best,
David
I'll definitely try it. I'm just not expecting 0.5WPC to be sufficient for critical listening. Mark Schneider has advised me that 100db+ sensitive speakers are required for critical listening.
I know that generally the 12" 49CZ are estimated to be 96dB, but I think they are more like 99-100dB, based on comparison to my 95dB (claimed) 2-way horns.
When I swap out the horns for the Zeniths and keep the volume the same, I get noticeably more detail and spl.
I have a Parts Express SPL meter at work. I should be able to get some data to at least compare the two.
Congrats! You're gonna be pleased.
Mmmm, mine are 10"..... Hopefully pretty similar.
@Poultrygeist did you notice any SPL difference between your 6" Zenith and the 12"?
If not happy with the 10" I guess I could buy a pair of 12" and enlarge the hole in my OB cabinets. Finished assembly of the second one today. Will apply wood filler to the second and leave 24 hours tomorrow.
The first one will be sanded tomorrow, the holes cut and then varnished. Then the fiddly stuff can begin :)
Painting project is almost done so I'll get my shop back to where I can make dust, and the APPJ is a day or two away, so I'm getting close to being able to build my new Zenith OB's. I grabbed a few 6AK5 tubes to mess with and have a pair of 6V6 to 6P1 converters so I can try out all my 6V6 tubes. I'm really excited to see how this ends up. I really like the idea of getting rid of a bunch of gear if this turn out how I hope. I'll post some pictures once I start building.
Shown here are my 8 inch Zeniths and I'd guess they are around 94dbs whereas the 12 inch versions are about 98dbs. I'm convinced all the Zenith Alnico's sound excellent.
Hi mjw21a,
Great ... looking forward to your thoughts on the pairing ...
The LTA site states that the MZ2 can:
"Drive high efficiency speakers (95db efficiency or higher) to adequate volume"
Although this is a little vague (adequate for who?), reports are that the Zeniths are about 97db, so that is already in the range. But of course, Mark Scheider probably knows best.
Just wondering, has anyone actually measured the Zeniths efficiency ? From my experience they are definitely more efficient than my BK-16 back horns which I think are about 95db, although how much more efficient I am unable to say.
All the best,
David
It only takes a tiny fraction of one watt to play the Zeniths at normal listening levels. I think Mr GITD has driven his with a 45 SET and that amp makes a single watt.
Thanks Poultrygeist ... one day I'd like to have an MZ2/3 or a decware SE84UFO driving my Zeniths ...
mjw21a, I just realized that you are starting with the 10" Zeniths ... it would still be great to get your feedback on those with the MZ3. Even if they might be a little less efficient than the 12" drivers, from reading different comments on the different size Zeniths, I suspect that there is a house sound ...
Well, I got home for lunch and the little APPJ mini and FX 01 were on my door step, so I wasted a little time putting the 802's in some old open back speaker box's I have left over from my touring days that I've been saving because they are too cool to get rid of. I threw the Zeniths in there just so I could test everything out, and am NOT going to leave them like this, but I was impatient to try everything out so I thought what the hell. 3 watts seem to be plenty and they could probably be happy with half that and still be loud as can be. Even though no placement consideration was taken and I really did just cobble it together where ever, I'm impressed by the outcome. It is a bit brighter sounding than I want and I don't feel any need for a tweeter on first listen, but I'm sure the box's and placement have a lot to do with that. So far I'm feeling pretty good about this and am looking forward to really getting into this.
Yes, I'm thinking I probably should have gone the 12" drivers. Ah well, we'll see how I go.
That's fantastic news for me. The Zenith are happy in an open back box. I figured they would be as that's basically how many of the old consoles were built :)
