Open Baffle Epiphany!
Ok, just wiring and the rear speaker cloth to be done on the left speaker. Then time to sand back and begin on the right cabinet.
Once complete a casual inspection shouldn't reveal it's DIY nature.
Damn they're heavy though and I haven't installed these big Mundorf L200 8.2mh inductors yet..... They won't hold back the Magnavox woofers ;)
Well I still haven't got my shop out of paint mode so no new OB's yet, but I have been fooling around with 6v6 tubes in the mini, and placement and I found that an extreme toe in really helps even the frequencies out. This was the case with my other OB's but once I put small sides on them this became less on an issue. The Zenith's in their temporary open box's don't seem to get the same help from having sides. I'll experiment more when I get some panels made and see how it goes. I was a little worried about it for a while , but hearing the difference placement makes I have regained my enthusiasm for this little experiment.
Time for me to wire these suckeres up :)
I've applied Ping Jing (like Dynamat Extreme) vibration deadener to the top and bottom of the cabinet. I've left the front and sides alone though. I figure it can only have a positive impact. ;)
Unfortunately I got the screws misaligned for the super tweeters so there's no way these can be passed off as anything but DIY now.... Ah well....
Looking good, now the impatient question, how do they sound?
Damn, I have misplaced the Western Electric solid core silk covered wire I'd intended to use for the project. Can't find it anywhere. It'll likely show up in a year or so.
I've put an emergency order in with Geoff at Aurealis Audio for 6m Dueland 16awg wire. Any further progress will need to await delivery of this. :(
Kind of frustrated now. I was keen as mustard to use these tonight....
Still affixed the big Mundorf inductors with zip ties though.
Copper stranded hook up wire is all you need.
Nah, I'll use the good stuff. I used Dueland in my Oatlon W2-1000F speakers too. Pretty fantastic stuff. I should have it Monday or Tuesday.
I'm using Miflex KPCU-1 for the super tweeter caps and the Mundorf inductors are particularly good so no point cheaping out on the wire. I only want to do this once. I hurt my back moving these things so I really don't want to move them again if at all possible..... They're seriously as heavy as the B&W DM16 speakers in the gym.
I suppose expensive wire is a good think if somehow it gives one peace of mind.
I've heard the difference it makes in my system so definitely worthwhile. If a system is insufficiently transparent to hear the difference between wiring then just think of the musical detail you're missing
That's alright.... Only I need to believe. It's my system ;)
Will get it wired up either Monday or Tuesday. Very much looking forward to hearing it for the first time. How long does it usually take for these old drivers to loosen up? They've probably not been used for 20+ years
Until the system is up and running and adjusted for best performance any comments on transparency and such are simply conjecture. I believe the system will sound pretty good even considering the compromises taken for the sake of domestic tranquillity. ;)
The 1957 Zenith donor console looked almost new and after I pulled the drivers they sat on a shelf in my garage for over 5 years.
But when I finally fired them up they sounded excellent from the get go.
Aye, open back is a compromise though that said I've only found reference to one person on Audio Circle who has done one. He says it gives added deeper bass along with ability to work in closer proximity to walls, furniture etc. I'm thinking it will work better for me sonically than a true open baffle with my space restrictions taken into consideration.
I'm the end I guess I'll only know once I try it, and never even know if worse than a true open baffle as I'll not have tried one.
IMO you should try an open baffle, even if the room is not feasible for it as a permanent arrangement. It's an eye opener + you get to know that sound and then when you build your (open) box, you can hear what each element does and try to find ways to get as much of the open baffle magic but fill it out in the right places and compromise so that you get something that works in your room but doesn't completely lock the driver in a box. Of course all that takes time, to make those experiments... so in that sense, your approach might be a bit more merciful :) Especially if you get an end result that sounds good - if it sounds good and you don't know how much better it could sound, there's no pain :P
