Open Baffle Epiphany!
I'm sure the 10 inch Zeniths can be spectacular.
I figured a little less efficiency on the Zenith will allow more noticeable bass from the 15" Magnavox drivers so better balanced overall.... Problem is that a lower efficiency is a definite negative when it comes to driving these from the MZ3.... Ah, tradeoffs :(
The 802's are so impressive I can't help but take pictures. Here they are without their H-frames.
Sexy looking drivers. Going to be a shame to hide mine behind speakers cloth. Still, a necessity to make my wife happy and keep the baby out when she begins to crawl.
I had not added the RS tweeters when this picture was taken. At the time my part of the country had just experienced a solar eclipse and these were reminiscent of that event.
Getting there
Reasonable WAF I think. Very very happy considering this is my first time working with wood :)
The hole in the top is for my Skar Audio VX1-ST bullet tweeter. Unfortunately the screws it came with are not long enough so I'll need to make a trip to Bunnings tomorrow. Probably no further progress for another 4 days as its forecast to rain for 4 days. :(
nice work :thumbsup:
The grilles are on however I'm yet to cut the holes and install drivers. It'll get there. It's nice to see it start to look like a real speaker though :)
The downside is my wife has pronounced she doesn't like it already. They're too big apparently :(
Bugger it. I'm still going to use them. ;)
I doubt those grills will fit unless you mount the Zeniths to the rear of the baffle or perhaps the grills are slightly larger than the drivers? .
Mmmm, no idea. The 15" Magnavox fit in perfectly.... The Zenith are a funny shape though aren't they? Might have to mount them from the back after all.
The drivers absolutely must be protected from kids and the dog so the grilles are absolutely required.
Poultrygeist, how do you set your crossover for the Alpha 15's? And do you have any recommendations on getting the most out of my 802's? I suspect that I will probably end up wanting something to fill out the Zeniths more than just adding my pair of powered subs. On first examination in very much less than ideal conditions, I found them very detailed but lacking lows and low mids. I'm sure messing with placement and putting them in a proper OB instead of just open back box's will smooth some of that out, but on first go they are lacking quite a bit in the lower registers.
I received my Zenith 49CZ802s today. They survived shipping but are very dirty and grimy. I will have to clean them up for sure as I feel icky handling them.
Next step is to make a baffle to give them a test play.
I bi-amp with a SET amp driving the Zeniths and a TPA3116 amp driving the Alphas. No crossover or filter on the Zeniths which run full range but I use an active crossover for the Alphas.
Using a Yung SD100 plate amp which has a built in crossover is another option to power the Alphas.
I know you're not using a crossover with the zeniths I was curious where you set the crossover on the Alphas to compliment the zeniths.
Yup, my Zeniths and speaker cloth arrived today. Just my new amp, tubes, coupling caps etc to come now.
Ok, looks like the little ears on the 10" Zenith are about 1mm bigger all up than the grilles. I'll be able to make them fit. The more annoying but will be drilling holes through the metal grille mount. They don't line up. Doable though.
