Open Baffle Epiphany!
Ha, I must have missed it. All good, a wonderful and informative thread so far. I'll definitely see what the effects of extending the back up behind the bass drivers has.... I'm very curious about that.
Converting to double U frames wilk be interesting also.
OK, I post an answer to a question about alnico vs. ceramic magnet speakers and it's an "extraneous post"?
ummm, allrighty then I guess. We can't discuss speakers in a speaker forum?
I must have missed something in the rules...?
Alnico and Ceramic have different focuses on the magnetic field to the voice coil. Some prefer alnico, which has a more focused field, over ceramic which spreads the field out more evenly. Guitar players have been aware of this for years.
Well, I've been messing around with the zeniths and have come to the conclusions that mine are just not happy getting full signal...
... as they sit, they just don't sound correct, and I've run out of ideas.
I'm not giving up, I'm already deep down the OB black hole. I just need to regroup and figure out what to do next.
I've just come across this DIY design using a full range driver with an 8kHz peak, and it uses a passive filter to tame the spike:
http://www.zaphaudio.com/audio-speaker18.html
The component values are unlikely to be correct for a completely different driver like yours, but it shows the format of the filter and maybe offers some encouragement.
The puzzling part is the Zenith 49CZ802 requires no filters and should sound absolutely stunning as is. And that's not just my experience.
I think halk's are defective. I'd listen to each individually to see if they sound the same but of course both could be bad.
I bought new drivers from PE once that played ok but sounded wonky. Returned them for replacements which sounded fine.
I haven't gotten back into the messing around with the Zenith's. I really burned out my ears messing around with them and have needed a break from critical listening. A big problem is I have no point of reference of how they can/should sound so I'm at a slight disadvantage in diagnosing them, but I still haven't given up on them.
To me, very smooth and refined, almost liquid sounding. Rich tone with instruments like organ, strings, woodwind, guitar, electric guitar etc. Really reveals the weakness in a recording yet manages to still sound good. I do find them lacking in the top end with shimmer of cymbals, top hats etc totally absent without a tweeter.
I think the lack of the top end is part of the reason they're so composed and never sound congested with complex material like other full rangers like the Dayton PS220-8. It's an issue easily rectified with a helper tweeter.
Inside of a meter they can sound a little harsh though from my listening position 2m away they're rather excellent.
Are they the best thing out there? Probably not though I think it would take significantly more money to beat them, even at the inflated cost it takes for me to import from the US with the exchange rate, shipping, tax and import duty.
That said it sounds like either they're not sounding right in your room or this pair are defective in some way. I'd not be surprised if you go another direction after your troubles :(
I certainly prefer the AlNiCo for the clean sound, and isn't that what we are striving for here? It has more of a "presence" about it, almost like just a touch of reverb. I can see where this would better capture/simulate the ambience of a big hall. Comparatively, the ceramic sounds "dry."
