Open Baffle Epiphany!
BTW, the featured artist at the Gila Bend amphitheater on my garden railroad is OAXACA LOUGIE doing his "IN YO FACE!" tour. He is often backed by the "Flem Fatales."
Funny, Halkaloogie was my nickname growing up and through my 20's, my last name is oddly close to it and slightly unpronouncable. A substitute teacher called me that once during roll call and it stuck. Now my friends just refer to me as that jerk.
And that's a pretty amazing backyard train set
Megaphone singing was once quite popular with crooners.
With the tech back then just about everything sounded like it came through a megaphone :D
I kid, this surprisingly sounds quite decent for a record from '29.
Much clearer than some of the R&R recordings from the 50's/early 60's for sure.
Found this picture of the Omega folding wing OB's that never made it into production. I think not because of it's sound but it's too simple in appearance and so easily duplicated that it would be difficult to justify a high enough price tag. One of the longest audio threads on open baffles, "The Gravity Well of a Dark Star" at AC inspired this design and is probably responsible today for the increased popularity of OB's. If you're into OB's or think you could be it's a good way to spend a day.
https://www.audiocircle.com/index.php?topic=19253.0
The OP said that removing frequencies proved fatiguing to him. The general consensus was that this is not possible and the opposite must be true.
A megaphone removes the lower and higher frequencies creating a band pass filter. But it is fatiguing to listen to someone on a megaphone for long periods. This is just a case that back's the OP's contention that removing frequencies can be more fatiguing, that's all.
No it's not the removed frequencies that present the problem, it's what the megaphone does to the frequencies that remain.
From another site. It appears that the megaphone takes away frequency response and dynamic range.
I am trying to figure out the best way to make VO sound like it is coming through a megaphone, any tips? Audition 3.01.
Thanks!
Correct Answerby Jay Moore on Aug 27, 2009 7:00 AM
Here are some general tips that should get you in the right direction:
use the FFT filter to create a tight filtered spectrum. You want to kill everything above 3 or 4 khz and everything below say 500hz. Megaphones have horrible frequency response.
dynamic compression. a megaphone's horn has no real dynamics to speak off...using dynamic compression will help to simulate this better
distortion: a megaphone adds a slight bit of distortion...you may be able to mimic this with enough compression..
mostly the biggies are the stuff you do in FFT and dynamic compression.
you can add echo if you want.
I like the baffle within a baffle, that's a neat trick.
On another note the little SET amp will never have sufficient channel separation so going to source a Wavebourn Edelweiss-3 utilizing sweep tubes from aircraft radar systems. Similar cost to fully outfitting the GU32 amp with better transformers, rewiring, upgrading all caps etc
It's being converted to 240VAC and the volume knob replaced with a switch to allow more impedances for speaker matching. All point to point so I can change the coupling caps should I wish to ;)
Got to say that everything Glow in the Dark wrote about the 6" Chinese Diatone P610 clone full range driver is shot on. Just spectacular performance. I'd put it in the same level of performance as the Zenith, though less efficient.
I've only tried mine in a closed cabinet though I'm incredibly impressed at their performance and smooth refined sound. Incredible the quality of some of the gear coming out in of China right now.
No doubt excellent speakers. I really enjoy reading his blog and he updates it often with new reviews. Don't know if you've read his comments on the Altec 601C but these are highly valued here on AK but he says they aren't in the same league with the Zeniths.
http://glowinthedarkaudio.com/altec601c-duplex.html
The Altecs mightn't be competitive though he's stated he generally doesn't like horn tweeters so it could well be down to personal taste, or even mismatched cabinet. Too many variables to consider.
I am grateful to him, and yourself for bringing the Zeniths to my attention.... Also the Diatone clones. They're one of the great audio bargains. The 6" Diatone P610 clone destroys the 8" Dayton PS220-8 and sounds an awful lot like an alnico driver despite being ferrite magnet. Really quite incredible.
Mmm, the switch being installed in the Edelweiss-3 isn't for additional impedances. My bad. It's to enable and disable negative output resistance to compensate DCR of speakers. Allows for better bass response with less efficient speakers. Will probably need to be turned off with mine. I'll have to experiment.
