Open Baffle Epiphany!
One thing I've learned over the years from fooling with OB's. Woofers and subs are just not that critical in terms of SQ amplification. As long as you have adequate power and a decent filter/crossover
you're good to go. Amplification for the full range drivers is where you need to spend the money.
One of the first amps I used to drive a pair of OB woofers was an ancient Denon AV receiver. Sounded as good as anything else I've tried and how nice it was to have a remote to control the volume.
The current amp I use to drive the woofers on my Zenith/H-frame OB's is a $10 TPA3116 amplifying the filtered signal from a Behringer active. If you look closely you can see that TPA in this picture with it's silver knob and toggle switch.
An absolute sleeper that I'm anxious to place in some decent baffles are the Radio Shack 40-1286 full rangers. Until I can clean out the garage they're hanging above a AV system in a bedroom closet. I bought my pair for around $20 but that's been a couple of years ago. I can visualize these paired with Eminence Alpha 15A on flat baffles.
Those were so cheap back in the day. Not too long ago I saw a pair brand new in the box on CL for $20. I called and they were already gone. They should sound decent. Back in the 70's a friend put a pair in the rear deck of a VW bug. They just fit in that space. They sounded really good.
Decided I must at least try the F-15 in a Betsy size Barrel. I simply enlarged the 8" driver hole in the baffles I already had. Boy what a treat I may be sticking with these (In a nicer baffle of course) I just LOVE how the smaller baffle DISAPPEARS every bit of the music is up above for a superb sound stage. Bass was also quite shocking. The stand up bass in Sotho Blue by Abdullah Ibrahim was really nice. I find with the larger baffles they can not do the disappearing act nearly as well they are so big you have no choice but to see them
77
What amp are you using up top ?
Bottlehead 2a3 SET as shown above
Thought I saw Bottlehead, could not tell if 2a3 or ? So how quiet are they and what Pre do you use ? Just call me nosy :biggrin: I am still trying to lock down the gear angle. I am hoping the transcendent Masterpiece 300B will be my final pre-amp but the gain may be a bit much. I might have to look into another truth by Ed. If we could only afford to keep it all
I am not good at forgetting placement and or imagining something is no longer there.
I'm not either, but sometimes my eyes fool me and tell me there is a problem that doesn't really exist.
IME when it comes to soundstage and imaging everything sounds better with my eyes closed or at night with the lights out.
Most often I use this Bottlehead Foreplay III. But in the last picture I see I'm using an Aric. I really like my SMD DACT passive as well. I get a little hum with the 2a3 amps but it goes away with sufficient warm up.
The Truth preamp is a winner if you don't need the gain of a tube preamp. I've heard it many times at Ed's place and always come away impressed.
If looking for a modest amp and into to the sound of tubes, I'd suggest that any of a number of EL-84 designs can be a pretty good fit for the efficiency's of OB.
The push-pull 84 is about 15 or a little more watts, which fits nicely into more than a little but less than too much. A set of the EL-84's is readily available and doesn't break the bank. The sonics are nicely dynamic in about every model using them that I've heard. If you wind up with a really efficient driver setup, strapped to triode operation drops wattage to about 4-5 and is a really, really nice presentation of music.
Now if you don't mind burning the higher dollar tubes like the 2A3 or 300B, then certainly single ended is a great way to go. I'd just suggest that the 84 is a winner in the dynamic department, cost department and yet fits into the power area for OB use pretty nicely versatile. Lots of options though and lots of different tastes in users.
EV3
The EL-84 amps can be excellent and the tubes are far more affordable than the big bottle DHT tubes like the 300B, 2a3 or 45.
Mine is a Dennis Had Magnavox redux. It's single ended not push-pull so it makes about 4 watts per channel.
I have a Carver VTA20s Black Magic that really sings 20 wpc uses a quad of the EL84m and a pair of 12ax..............Dead quiet very SET like in sound, On the Lii F-15 it really sounds great
:p
box (open in the back of course), packing tape, speaker out of a old "cinema sounds" projector TV, tossed on a chair, driven by a Radio Shack SA-1001... you guys and you fancy stuff he he he
I needed tunes in the garage so I cobbled these together from parts and baffles I had on hand. They use 8 inch Radio Shack 40-1286c full range drivers which were dirt cheap back in the day. Now days the price has increased since folks discovered they work amazingly well in open baffles. These drivers have a Qts above 1.0 so they make some bass on their own.
The tweeters are open back B&G Neo 3 planars and the helper woofers are the old standby Alphas. This set up will put a smile on your face, real toe tappers they are and before you know it you'll be up dancing. My wife caught me doing just that yesterday.:biggrin:
Using an old Marantz I plan to sell and it's a good match for these OB's. A plate amp drives the Alphas and it's signal comes from the Marantz's pre-outs. The source is an Integra DVD/CD player
I now have the Lowther DX3's in MJK's MLTL speakers that I recently built. That left me with with the double Alpha baffles and a hole where the Lowthers used to be. Remembering how good the 8 inch Zenith alnico's sounded I fashioned a supra P1010001.jpeg baffle for them and installed them on the double Alpha baffle. I wish I could tell you the model number of these no name Zeniths as they are crazy good in this set up. The inexpensive Realistic 40-1286c as shown in the previous post are good but not in the class with the more efficient highly resolving Zeniths.
Not thinking what I was doing I hooked up all four Alphas in parallel to a single 300 watt plate amp. When I powered it up I got a loud pop. Scared the crap out of me. The class d plate amp still works but now runs hot which it never did before. I realized that the plate amp was attempting to drive a 2 ohm load. I've retired the plate amp and now power all four Alphas with a $10 TPA3116. I'm using the sub out and controls on a Behringer CX-2310 active to feed the TPA amp and low pass the Alphas. The TPA amp benefits greatly from the Behringer's extra gain and it's more accurate crossover. In this picture you can see the antique Marantz powering the Zeniths and above the Integra DVD/CD player is the Behringer. The two knobs in the middle section are the sub gain and crossover controls. In the little wood case below is the TPA3116 amp.
