Poultrygeist
Lunatic Member
I don't care how good those may sound. They're right at the top of my fugly list.
Beauty is only a light switch away.
Single Driver OB with Bass to spare you ask ? I submit the Decware ZF15M or L I built the M and I can tell you I now have a quad of the Eminence Alphas tucked away in bags gathering Dust
I'm confused, are those drivers the same as the Lii F15's?
I have the F-15's but have not yet heard them in open baffles. I'm no wood-worker...I already had cabinets handy...BIG ones...so put them in there...I'm very curious what differences I would hear in LARGE cabinets vs. open baffles...
These F-15's are the best vinyl speakers I've ever heard. The sound is just so ALIVE and vivid. The lack of crossover I'm sure is a big factor there.
I fear shipping would make things cost prohibitive as well. My Baffles are barrel shape and stand 36 inches tall and 29 inches wide 1.75 inches thick and I am quite content to NOT use Bass augmentation. I have smaller baffles as well and they do nicely but IMHO they really need bass Aug. to sound there best
The beauty of OB's is they are so easily bi-amped and with the mains running full range all that's needed is to filter the woofers. Passive crossovers can literally suck the life out of the music. Their effects are even worse with SET amps.
For the TRUE single driver OB experience you will want to have a decent size baffle with decent heft, I would offer to help with the baffles but Iowa is a bit to much of a driveI fear shipping would make things cost prohibitive as well. My Baffles are barrel shape and stand 36 inches tall and 29 inches wide 1.75 inches thick and I am quite content to NOT use Bass augmentation. I have smaller baffles as well and they do nicely but IMHO they really need bass Aug. to sound there best
Just joined and happily browsing through the posts I found yours, which almost gives me the last bits of info I need to place my Audio Nirvana Classic 15s in an OB paired with Eminence Alpha 15a's. Only thing, I've never used an active crossover and am generally technically challenged! There I said it. Feels good to come clean LOL. It sounds like I will need an active crossover but having never used one I could use some splaining as to how they are set up, adjusted etc. Also, if I use an active crossover in order to get the signal to both the AN and Eminence drivers, I take it that I have to have that crossover in front of both the SET amp (for the ANs) and whatever amp I choose to run the Alphas. If I need a separate preamp with an active crossover how might that work? I'd like to keep the signal to the AN drivers as simple and possible.
Lastly, is it important to keep the AN and Alphas a particular distance apart on the baffle?
Being new to AK, I am amazed at how deep this hobby/obsession goes, and again, I do apologize if I'm technically behind the curve so to speak.
Maybe I'll keep the Lii drivers and see if I can sell the cabinets... That would clear up some much-needed space right now but allow me to keep the drivers. I do want to try open baffle...both with single driver and also a three-way with a woofer and a ribbon tweeter. What if I just leave the backs off of my large cabinets...maybe that will get me a little bit closer to the open baffle sound?
I Built that EXACT system some time back, You do not need an active crossover. just source a Crown XLS1002 Amp (300.00 ish) and it has a built in low pass. set that to desired Crossover point (I prefer around 150 Hz) have one output from your pre running to the amp that powers the AN15, and a 2nd output from your pre running to the crown. Adjust the bass gain to mate well with the AN Gain your set and running. If your pre only has one output get a pair of splitters or Y cables like those used for subs
Now that I think about it, is it possible to just run a high level signal from the tube amp speaker terminals to the Crown's?
