Open Baffle Epiphany!
99% of the time I'm content with the Alphas in OB covering 40hz. After all the great majority of the music I listen to doesn't go any lower. A few years back I got into those fast little 8" Dayton kit subs and built two of them. I also built two bucket subs. So where space allows I often augment the Alphas with a sub or two. Not so much because they're needed but because I have them.
Yesterday I was powering my 4 OB Alphas in parallel with an FX Audio FX252A class D I picked up from PE on close out. I may have cooked the FX as I don't think it handles 4 ohm loads like the TPA3116 amps. I am now strongly considering a Crown XLS 1002 to drive the Alphas but it may be over kill as the Alpha's sensitivity is fairly high.
I've been playing with an Ashly active which after much fiddling sounds pretty darn good crossing over the Alphas and 8" Zenith alnico's. I'm using only class D amps plus a tube preamp. My experience with the Ashly and SET amp combo left much to be desired. The class D amps and Ashly are a much better match.
I have every part and piece I learned about here ready to start the AN 15 and Alpha 15a project. Should be done by next week.
That box of Alpha's delivered today is mighty light! Its hard to believe they have much output, but I've literally no idea given OB is new to me and trust what I've read here. So I'm expecting good things but still plan on getting a sealed sub.
BTW, what is involved in placing some sort of gasket material between the baffle and driver?
Anyway, I'll post a picture of the finished product and let you know what I think in comparison to prior experience.
Now I'll just hope my scrappy Chinese el 34 set doesn't give out (can't afford another SET now)... that right channel is beginning to sound a little if-y.
Thanks and respect to everyone here.
You don't need heavy motors to get that high Qts that OB woofers require. Spatial's woofers are just modified Alphas as well as the Hawthorne Augies ( RIP ). For years Emerald Physics used off the shelf Alphas.
Don't the Alphas come with a gasket? If not or if you want a thicker gasket you can use thin weather stripping or Mortite rope caulk from Home Depot. Lowes doesn't carry Mortite.
Carefully scrape the pins on your amp's tubes with an exacto blade.
Thanks for yet more insights!
I'm about to start building but have so many other other things I HAVE) to do!
Anyway, I've not found much about OB imaging precision compared to boxes, especially with live verses studio productions, where imaging is actively (and usually) controlled. Would love to hear any thoughts on this.
In any case, from all I've read here and elsewhere, I'm confident this is going to be something different but a difference I will really enjoy.
Good imaging to me is the ability to pick out instruments in the soundstage. With OB's you get great depth and holographics. Often you can hear instruments that appear to be placed behind, to the sides and above the OB's. Some believe that skinnier baffles can contribute to better imaging. I can't say because all my baffles at no wider than 20 inches are on the skinny side so there's nothing I have to compare them to.
Interesting take on the Baffle width Pgeist. I have tried both narrow and wide baffles though the widest has been 29". I might agree with that assessment though I must admit its not a large margin of loss. I think though I cannot prove this you need some space between the listener and the speakers let them bloom. My room is to small for anything over 8 feet with the speakers 3 feet off the front wall. I get some information at height. I also get some information at my knees. I contribute most of this to the source. The stage width is super wide and as deep as ones room will allow. I hope to have a better room soon
My wife and I have been self isolating since March so projects have kept us from developing cabin fever. With the garage OB's I thought I was done with audio projects until remembering the old radio cabinet in the attic. It's been in the family since new but it's tube amp and speakers disappeared long ago. My resto-mod plan is to add a pair of full range speakers powered by a class d amp. It's never had a back so it was always an H-frame OB. Instead of a tuner I'll be using the more versatile Echo Input which will play any station upon request. Since signing up for Amazon HD the variety of tunes to stream is endless.
Beautiful cabinet, and a great project. Like in so many places, stereo is a waste here, so why not just go with one full range speaker. There are many ways to go mono from a stereo source, including line level and speaker level transformers from Edcor.
I could but hate to break up a pair. :)
It would be no trouble as I have a mono class D amp and if I don't like the sound of stereo with drivers so close together I can give mono a try.
I'm powering the open backs with a TPA3116 amp. The little disc on top is an Echo Input. The sound from the front is decent but not as good as the sound from the rear. Since the drivers are at the front, this is more of a U-frame than an H-frame. I'll probably try moving the baffle to the center of the cabinet. I've also got some high Qts 10 inch drivers that are still in the box from a PE buy out several years ago. They would be a tight squeeze but I may give them a try.
That’s a cool idea
Mine are 3/4’s open...
Been experimenting with different amounts of power into the Decware ZF15M (Clones) I have to say the PP is sounding mighty fine. OB designs being lean by nature really benefit from the added power and PP tube design amps. The bass can get down and dirty with HUGE impact. Still play nicely at lower volumes as well
Jumped into the OB world with some Emerald Physics EP 3.4's. Still waiting on the crossovers to arrive, it's been a "process" dealing with them. Either way, subs are prepped and excited to hear how they sound! Oh when you setup your driveway like a graveyard the neighbors flock;)
A friend of mine came close to buying out the remaining stock from Mark down in TX spent 11K he got KCII Pro, 3.4, 4.4, and 2.4 as well as amps conditioners etc... that was about 6 weeks ago and he is still waiting on Mark to deliver some goods
On the positive side he says the 3.4 with subs sound great, but he prefers the 4.4. On the 2.4 he is under the impression they REQUIRE higher power amps to get the woofers to move and make decent bass. I bet you will have some fun with them
Yes I can tell you this has been a frustrating process. Facts, time liness, dates and untruths abound. Ill keep it over the counter for now.
Excited to hear them.
:thumbsup:
With my new Node 2i streaming Amazon HD I'm discovering new types of music for the OB's. I'm an old school acoustic jazz guy but I'm here to tell you the high-rez techno and electronic stuff is jaw dropping good on the Zenith/Alpha H-frames. I've powering the H-frames with 300 watts and the driving, pounding bass is so detailed and precise I'm besides myself. I enjoy changing up lots of my stuff but this combo won't be touched.
