That is really really hard to say. Depends on what co-ax you use, and what you expect. I bought these speakers to use with an Electra Print 300B Custom amp, which is good for 8 wpc. Efficiency of the co-ax is 94 dB, and the crossover is 6sB per octave with Alpha Core coils, Clarity caps, and Mills resistor. It sounded nice with the EP gear, but a bit too warm and romantic for my taste, that kind of classic British sound.
I experimented with a few things. but what finally did the trick for me was a 33 wpc Class A battery powered amp based on a Nelson Pass A40 circuit, along with an active SS pre-amp. I found the c combination to have the majority of that SET magic and yet open the top end up in a way that the tubes didn't. Hersey I know, as I have used SET for over a decade. But this is what worked for me.
As far as a narrow baffle, these are around 15 inches wide as I recall. They are good for 50 hertz, and then I roll a subwoofer in. The narrower the baffle, the less bass extension you are going to get. So its a trade off.
Regards
Mister Pig
