Hadn't thought about over-excursion. Active crossover it is then.
Thanks for the links, I've read the papers, understanding some of what Martin King says, hopefully the parts that matter. I'll go with the Alphas in the H-frame. Is it correct that the internal dimensions of the frame should be 16" x 16" x 16" with the board holding the Alphas centered equidistant front and back?
The H-frame is 15" deep (total) with the Alpha 15a mid-way (7.5"). Technical reasons are given in MJK's papers. 16" x 16" internal sounds right; should be just big enough for the Alpha 15a to fit in. Because the Alpha 15a is recessed into the H-frame, you must limit the high freqs coming from it. Think how bad a mid-range would sound if it were down in a tube! So pay attention to MJK's recommendation for XO. Again, the electrical XO isn't the same as the acoustic XO-- due to the effect of the H-frame. Again details are in MJK's papers.
Cheers, Jim
updates, anyone? or are we taking the summer off?![]()
Eric, now when are going to build yours?
I know you're chomping at the bits. :yes:
LOL ! i am taking the summer off !![]()
I stuck some Acoustic Elegance IB15's into some H-frames that were once occupied by Alpha 15a's. Certainly an improvement in most every area, most notably sheer output capability. The IB15's probably weigh 3x as much as the Alphas, so I think my H-frame "enclosures" need to be bolstered and the magnets supported to optimize the performance of the big bad driver.
No doubt. They would be the single biggest upgrade that someone into OBs can make, IMO.
Kinda shows you aren't into OB's
